Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Do I have a high volume or high pressure oil pump ?
Old 12-15-2008, 02:15 PM
y2k600f4 y2k600f4 is offline
Thanks 68NovaSS and Jsup.
My guess was the high oil pressure was due to tight tolerances and was just concerned if I should worry about anything. I was having some issues of possibly oil blow-by past the rings and while investigating I was curious if high oil pressure could attribute to the problem, maybe too much oil in the cylinders and some is getting past the rings ? I was running 10W30 and changed to 10W40 due to my other problem.
