We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 09-08-2008, 06:32 PM
BRSleeper2 BRSleeper2 is offline
Do I have power or manual brakes?
I am sure this is a noob question... How do I determine if I have manual or power brakes? 78 Monte Carlo, came stock with 305. I am sure there is a very easy answer to this question and I will knock myself in the head when I hear it... but at least I will know.
Old 09-08-2008, 06:52 PM
Centerline's Avatar
Centerline Centerline is offline
HotRodsAndHemis.com
Centerline's barnstar
Wiki editor
Last wiki edit: Streetbeasts fraud controversy
Wiki Edits: 38
Take a look at the master cylinder in this picture. If you have power brakes it will have a large power booster behind the master cylinder like this one does. If you have manual brakes, which is unlikely, the big black power assist unit won't be there.
Old 09-08-2008, 06:57 PM
yes it has the brake booster... I was quite sure it was a power assisted brake system... but the not so knowledgeable guy at the parts store was trying to tell me it more than likely had a manual brake system. Thanks... I was right... Just want to be sure before buying the master cylinder.
Last edited by BRSleeper2 : 09-08-2008 at 06:58 PM. Reason: picture is there now lol
Old 09-08-2008, 07:12 PM
vsmidge68 vsmidge68 is offline
well if you want to really stump this guy go back to the store and tell him you need a heater core for a 1965 vw bug and watch him squirm...lol.
Old 09-08-2008, 07:51 PM
Chevrolet4x4s Chevrolet4x4s is offline
Chevrolet4x4s's barnstar
Wiki editor
Last wiki edit: How to title a hot rod
or a water pump for a 1965 Chevy Corvair,or radiator hose,or thermostat
Shane
Old 09-08-2008, 09:18 PM
Centerline's Avatar
HotRodsAndHemis.com
Wiki editor
Wiki Edits: 38
Or a kneuter valve for a 37 Hudson.
Old 09-08-2008, 09:55 PM
RODDER18's Avatar
RODDER18 RODDER18 is offline
Are you sure you need a master cylinder????
Old 09-09-2008, 10:55 AM
What I have is leakage between the master and the booster... I believe the master is leaking from the seal where the plunger contacts the master... Sound logical to you?
Old 09-09-2008, 11:09 AM
1ownerT's Avatar
1ownerT 1ownerT is offline
1ownerT's barnstar
Wiki editor
Last wiki edit: Building a new shop
Wiki Edits: 2
That is pretty typical of one going bad.
Old 09-09-2008, 04:29 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
T-bucket23's barnstar
Wiki editor
Last wiki edit: Troubleshooting alternators
Wiki Edits: 2
If you are not 100% sure of what you are doing with cars, the brake system is not a good blace to start. Find someone who has experience and have them show you how to do this job.
It is a simple change but can be very frustrating and dangerous if done incorrectly.
Chet
Old 09-09-2008, 04:35 PM
busterwivell busterwivell is offline
Yup, and the other lesson you learned is don't get mechanical advice from the kid behind the parts counter.........
Old 09-09-2008, 05:41 PM
matt167 matt167 is offline
matt167's barnstar
Wiki editor
Last wiki edit: Finding vacuum leaks
Wiki Edits: 31
brakes are by far the easiest repairs to make, but 1 of the most critical systems with the need to function correctly, to maintain safety with the vehicle.. that said, if you have not done this type of work, have someone do the master cylinder for you, but watch them do it, and how they do it.. maby even help them bleed the brakes.. this will give you an idea of what you need to do to make these repairs
Old 09-09-2008, 08:41 PM
I know from my question I seem like I am clueless... I have changed many master cylinders, brake lines, calipers etc... I just recently put the motor, tranny, custom driveshaft, exhaust etc in the car. I simply like to be 100% on all questions before I start things... I was 99.9% sure that I had power assisted brakes and that the master needed to be replaced. Again... I just like to be 100% But thank you for the concern... I definitely understand the importance of doing it right...
Old 09-11-2008, 09:46 PM
RODDER18's Avatar
Just trying to help...I encounter a lot of do-it-yourself customers who show up after what they replaced did not fix their problem. So I have a habit of asking a lot of questions.
"The first key to wisdom is constant and frequent questioning for by doubting we are led to question and by questioning we arrive at the truth"
"Peter Abelard"
Old 09-12-2008, 05:30 AM
Damn good quote...
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Do I have power or manual brakes?"
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 104 11-13-2008 07:40 PM
Disc brakes without power booster? KNanthrup Suspension - Brakes - Steering 10 01-10-2008 09:02 PM
Manual vs Power rack and pinion oldguy829 Suspension - Brakes - Steering 20 09-05-2007 02:58 PM
power brakes and power steering on a '63 impala SS Benni520 Hotrodders' Lounge 2 10-14-2002 09:49 PM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
