Do I have the Right Size Valve Spring Seat Cups?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 07:58 PM
texastomeh's Avatar
I recently ordered a set of bare EDL aluminum heads (#60059) from SUMMIT for my '63 T'Bird 390 4V. I also ordered a set of EDL valve spring seat cups (#5771) for my 1.50" OD valve springs that are part of a cam update planned with the new heads. The seat cups were back-ordered for a couple of weeks, but came yesterday. The cups fit the machined seat areas of the head and the valve guides perfectly.
My question is concerning how close should the ID (lip-to-lip) of the cup match the OD of the spring? My springs mic 1.50" (+/- a gnats whisker) OD. That is the reason I ordered the EDL-5771 seat cups - SUMMIT states that they are for 1.50" OD springs. However, all of the cups mic 1.55" (+/- a gw) ID lip-to-lip and the instruction sheet states: "The spring seat/cup has a register for the O.D. of the valve spring that has a 1.550" dia...".
Bottom-line is that I have 1.50" OD springs and 1.55" ID seat cups. Is this too much difference? Is it anything to be concerned about enough to look for cups with a ID closer to 1.50" or are these O.K. as is?
You opinion and advice is appreciated.
Thanx,
texastomeh
Old 01-17-2011, 03:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A +0.050" difference in the spring cup's ID to the spring's OD is perfectly acceptable.
Old 01-17-2011, 12:24 PM
texastomeh's Avatar
THANX!!
THAT is what I really needed to know!!
texastomeh
Valve spring size redride Engine 2 03-09-2009 03:26 PM
Aftermarket spring cups or let the springs rest on a shim? sizemoremk Engine 3 01-13-2006 02:51 PM
Help! Valve spring seat pressure? camaro 68 Engine 3 05-20-2005 11:43 AM
Valve Spring Seat Question Garbonzo Bojangles Hotrodding Basics 3 01-08-2005 12:09 PM
Valve spring seat pressure too high? 84Z Engine 1 07-24-2004 12:00 PM
