Do I need any additional trans cooling? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2005, 07:49 PM
Z-Money Pit's Avatar
I am running a Ford 302 and a C-4 transmission. (Normal everyday street driven). The stall speed on the trans is between 1600 and 1800 (its a TCI Saturday Night Special). I just placed an order for an aluminum radiator that has a trans cooler built in. Do you think this radiator set up will provide adequate trans fluid cooling or do you recommend running the trans fluid through the radiator then to a trans cooler?
Old 12-17-2005, 08:03 PM
cooler is allways better but it will do the job nicely
Car-toons I mean tunes! kringold Hotrodders' Lounge 107 10-20-2006 08:10 PM
tranny cooler spokesc Hotrodding Basics 22 12-23-2005 10:49 AM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
Manual trans cooling scott011422 Transmission - Rearend 7 07-07-2003 10:25 AM
