We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 02-01-2007, 09:01 PM
camaro freak camaro freak is offline
Do I need to change the brake booster rod?
I am getting mixed opinions. I am converting my 69 Camaro manual front drum brakes to power disc front and drum rear. Do I need to change the brake booster rod also? Thanks!
Old 02-02-2007, 05:03 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Yes you do, I cannot remember but a manual rod is either shorter or longer than a power booster rod. If you compare a manual M/C with a power M/C you will see the differance. One of them has a deeper recess for the actuation rod. I discovered this when I removed the booster from my 34 project.
Vince
Here's to you DoC, you will always be here.
My project 34
http://www.hotrodders.com/forum/34-...ght=34+progress
Old 02-02-2007, 07:09 PM
Thanks!
Hey, thanks for the info. Does anyone know how far the brake pedal at the pad should be from the gas pedal at the pad?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Do I need to change the brake booster rod?"
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Brake booster M&M Suspension - Brakes - Steering 5 03-31-2006 01:56 PM
Foose builds a real hot rod for a change Centerline Hotrodders' Lounge 10 03-21-2006 10:36 AM
Power Brake Booster swap camarochas Engine 4 06-01-2004 05:44 AM
Brake change out from manual to Power Disk SMatlock Suspension - Brakes - Steering 1 03-16-2004 03:18 PM
