do I need to install a stall speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2003, 10:19 PM
the ernster's Avatar
Red face do I need to install a stall speed?
I have a 79 camaro w/350 w/350 turbo and want to install a lunati 292 cam with 480 lift will I have to install a stall speed? It has a 308 gear.
Old 04-13-2003, 06:47 AM
jalopy45's Avatar
Cool
Would probably be a good idea to raise the stall speed so the the car can use the maximu torue range of the engine. The car now is probably set up with a 1450 stall torque convertor and your mid torque range of the engine is 2200 to 2700? Run a desktop dyno program to get an exact figure and then find a convertor that puts you in the ballpark.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 04-13-2003, 08:59 AM
Post
[quote]Originally posted by the ernster:
<strong>I have a 79 camaro w/350 w/350 turbo and want to install a lunati 292 cam with 480 lift will I have to install a stall speed? It has a 308 gear.</strong><hr></blockquote>
I like Lunati cams. Their catalog for the camshaft you are looking at (#00010) lists it as 292 Degrees, 230 at .050 with.480 lift at the valve says in the catalog........
Needs street converter and headers
Better save up and get a stall converter.....
