Do i need MLS gaskets for 5-8lbs of boost - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2013, 07:22 PM
menoaz's Avatar
It is going on a bbc 427. Only a drag car and have around 8.7 compression. I know its extra insurance to have them but do i really need them and how about 8-10 lbs of boostthxs
Old 09-29-2013, 07:37 PM
techinspector1's Avatar
Wiki Edits: 326
I don't think any of us can advise you on this. We have no idea of the integrity of the block or heads, surface finish, fasteners you will use, torque you will apply, propensity to spark knock, quality of fuel used, etc., etc.
Personally, I think you're a little too aggressive on the boost if your SCR is 8.7:1. Take a look at this tech chart from Blower Drive Service. Read boost across the top and SCR down the left side. You can see that they recommend 6 psi max for use with pump gas at 8.5:1 SCR.
https://www.blowerdriveservice.com/t...al-charts.html
Old 09-29-2013, 09:07 PM
Banned
Drag only car, likely he's running racing fuel of some kind. 10psi may be low.
The Following User Says Thank You to ap72 For This Useful Post:
techinspector1 (09-30-2013)
Old 09-30-2013, 09:24 PM
menoaz's Avatar
Thxs inspector, just gonna go with the JE mls gaskets to be safe.
Old 10-01-2013, 11:34 AM
spinn's Avatar
Not necessary . I run 6-9 psi on my vehicles that are forced induction. My c10 is supercharged, and is holding up well ( 1.5 years) with cast pistons and stock gmp gaskets. At 9.0 compression ratio with vortec heads, a performer edelbrock cam, MSD ignition with BTM, it is safe. Makes great power for a daily driver truck.
I would think a good wideband, or some O2 sensor air fuel tuning device, is most important when setting it up. It helped me work the kinks out in a hurry.
blower supercharger bbc
should i run a boost or boost 30inHg/20psi gauge ftpro2 Electrical 1 02-04-2008 09:27 AM
TV Boost and low/rev boost valves. Drewnashty Transmission - Rearend 2 06-06-2006 08:56 PM
MLS Head Gaskets TurboS10 Engine 9 07-04-2005 06:51 AM
Reusing MLS head gaskets Dano1972 Engine 8 04-01-2005 12:46 PM
Anyone use Mr. Gasket MLS head gaskets? TurboS10 Engine 1 12-07-2004 10:55 PM
