Do I need a NASCAR pinion support in my 9"??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2006, 12:33 PM
hotrodf1's Avatar
Chasing dreams with a ball bat
Hey,
Got a question: Do I need a steel NASCAR pinion support in my 9" Ford rear axle? The car is a 68 Camaro, about 3300 lbs, SBC 406, about 500HP, T-56 6 speed, 5.00 gears, Mickey Thompson ET Street Radials (325/50).
The car launches pretty good but not extremely hard. I am heard others here saying that the pinion support in the 9" is the weak link. Is this true? I was told when I put this axle under my car that I would have a real hard time blowing it up.
I need new gears and bearings in this thing anyway, and just thought I should upgrade if that's what is necessary.
Thanks for any info.
jer.
Old 06-17-2006, 10:20 PM
I think they are GREAT insurance ...
Look at the difference in the width of the bearing.
I always use them on my 32's ... and my cars are light ( 2200 to 2400 pounds ) and are on street tires MOST of the time ...
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 32 05-11-2007 07:22 PM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 07:58 AM
9" ford ring & pinion install. kid Transmission - Rearend 4 05-07-2003 09:25 PM
9" Pinion Torque 68NovaSS Transmission - Rearend 2 04-18-2003 04:48 AM
Narrowed 9" w/Centered Pinion 68NovaSS Transmission - Rearend 5 12-11-2002 02:57 AM
