Do I need New Head Gaskets? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2012, 05:14 PM
I put heads on, torqued to specs and had to remove them 2 days later. Never started the engine. It has no oil or coolant in it yet. I didn't do anything. So, do I need new gaskets?
Thanks
Willy
Old 02-06-2012, 05:50 PM
poncho62's Avatar
Wiki Edits: 5
I would not take a chance on them
Old 02-06-2012, 06:00 PM
reuse
Thanks
Willy
spray on high tack both sides lightly and should work,if yu inst on same bank as befor
Old 02-06-2012, 06:05 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
if you put them back on the same side theycame off of.. and not upside down.. you can reuse them.
IT BE NO DIFFERENT THAN THE OLD SCHOOL WAY of torque'n them down, running it then after a few heat cycles, backing off the bolts and retorque'n them..
Old 02-06-2012, 06:41 PM
LATECH's Avatar
If you used a composite , you could get away with it.
A MLS (Multi layered steel) is usually stamped with "reliefs" and they are to help in sealing, they flatten out and Post stress the area of gasket that is reliefed so to provide additional surface tension that improves seal and holding capability.
I have heard guys here reusing cometic head gaskets after using with no trouble
MLS gaskets in some applications actually require tightening and loosening and re torqueing, subaru is that way. Dodge Neon is MLS and exactly opposite, also requires a spray on sealer for the OEM gasket, Fel Pro coats theres.
I guess in short...yes you can. A composite is more forgiving and I would if necessary, reuse it. An MLS, unless the manufacturer toqrue procedure calls for torqueing then loosening and retorqueing, I wouldnt re use it.
Which Head Gaskets? 65malibuSS Engine 2 08-18-2010 02:53 PM
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
head gaskets!!!! thefloyd1973 Engine 1 04-24-2007 02:06 PM
SBC Head gaskets.....which ones? TheZaZ Engine 6 03-15-2003 09:36 AM
Head Gaskets HotRodS10 Engine 4 08-13-2002 04:30 PM
