Do I need a Pinion Snubber?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2013, 01:12 PM
Finishing up my 62 Studebaker Lark converted to a 327 Chevy with Ford 8.8 traction loc rear. I've got a Muncie M21 and 3:73 gears. The car was a 6 cylinder automatic and has no type of pinion snubber. Should I install one? I've seen some adjustable types, Would I install it on the axle housing or on the floor above it? Would traction bars accomplish the same thing? This isn't a race car, but I will get on it once in a while on the street. The car is pretty light, probably about 3000 lbs. Thanks
Old 07-08-2013, 01:15 PM
big gear head's Avatar
High Performance Rear Ends
Traction bars would probably work better. The old slapper bars work pretty good, but also look into the Cal-Trax bars and the Competition Engineering bars.
Old 07-09-2013, 08:53 AM
S10xGN's Avatar
Gotta love a turbo!
ASSuming the car is leaf-sprung, what BGH said. Cal-trac's would be the best $350 you ever spent...
Russ
10 bolt pinion snubber replacement sapsz28 Transmission - Rearend 7 07-18-2012 04:56 PM
Mustang II rack and pinion, pinion Jim H Suspension - Brakes - Steering 3 02-23-2012 11:58 AM
pinion nut welded to pinion GMR Transmission - Rearend 7 02-21-2007 08:47 PM
ladder bar snubber? onecoomofo Suspension - Brakes - Steering 3 03-18-2006 06:09 PM
ring and pinion help Pontiacman Transmission - Rearend 0 11-13-2003 05:09 PM
