Do i need to put in special lube for a posi? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2006, 07:23 PM
took a rear end of a cutlass 12 bolt, 3.2??? gear ratio . better than what i had in there. any ways there was a tag that said put limited slip oil in there. should i? what would i use?? whats the best?
Old 10-26-2006, 07:40 PM
poncho62's Avatar
Wiki Edits: 5
Yes.............you can get it at GM or most auto parts srores
Old 10-26-2006, 10:16 PM
Go the GM parts counter and ask for a bottle of Positraction Additive. If he doesn't know what you're talking about, go to the next guy.
Pour it into the rear end before you put the oil in.
Old 10-27-2006, 04:00 PM
Most of the parts stores (Autozone, etc.) also carry it, back in the area where they have axle grease and gear lubricant.
Bruce
Old 10-28-2006, 01:13 PM
Posi Lube
I have had my 68 Chevelle with a 12 bolt posi init and have tried other posi additives from name brand oil companies and I have drained them back out because of heat and "snapping and popping" after the rear was up to temp. Without altering the clutches in the rear Just adding the GM lube It is fine and never acts up. It is a small 4 -8 oz bottle used to be clear plastic.
Old 10-29-2006, 07:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Mobil 1 syn gear oil will solve the problem of needing an additive.... it has worked well for me.
Posi Rear end gear oil problem stinky jinx Transmission - Rearend 16 05-14-2006 02:02 PM
Engine Assembly Lube ? bowtieorbust Engine 11 11-09-2004 11:24 AM
Anything special to put roller cam in 400 block? sb72elcamino350 Engine 1 04-09-2004 11:12 PM
Where can i get a posi Dreadlord Transmission - Rearend 9 01-20-2004 08:15 AM
