Do I need a rag joint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2004, 01:49 PM
Last journal entry: Body work
I'm using a power mustang II rack that I'll be mating to a late model gm column. I don't have much room at the rack input shaft, so the stock rag joint wont work. Is it really nessesary to have a rag joint, or will I have vibration in the wheel without it? Also, can the joint be located at the column end instead?
Old 10-27-2004, 02:49 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
steering joints
Borgeson makes some small u joints for this app..and yup probably need them to absorb misalignment in the steering column..Most of the online speed shops carry the things so they should be available easily..common issue to have little or no clearance on the steering shaft..You are not alone on this one..
It may be necessary to tweak the install a bit to get it all in there..
Old 10-27-2004, 06:59 PM
4 Jaw Chuck's Avatar
All kinds of options at Borgeson.com.
— Han Solo
Old 10-28-2004, 11:31 AM
302 Z28's Avatar
A rag joint is not necessary, but certainly desirable. I second the Borgeson unit, or the Flaming River unit, both high quality.
Vince
Old 11-02-2004, 12:52 PM
Silentlion_69's Avatar
Duck Tape & WD 40
Last journal entry: No more Vehicle
this probably sounds dumb but what is a rag joint? I've never heard of one
Old 11-02-2004, 01:31 PM
Wiki Edits: 3
good question
If you look at where the steering column shaft attaches to the steering box (on most cars) you will see a joint that has a sort of heavy fabric washer in the middle of it..
These joints do a couple of things..One is that they absorb any varience in shaft angularity and two they absorb vibration that may be transmitted up the steering shaft to the steering wheel..
Since they have this "fabric" in the middle of them they are called "rag joints" This fabiric material is a multi ply material similar to that used in the construction of tires or heavy conveyor belting..
Probably more than you wanted to know..
The Following User Says Thank You to OneMoreTime For This Useful Post:
GARY HOOTEN (03-08-2015)
