Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Do I need residual pressure valves?
Old 06-19-2011, 07:30 PM
1930u's Avatar
1930u 1930u is offline
Last journal entry: 1930u Its just been sitting
To all- My Corvette style master cylinder is mounted at a right angle behind the dash. I'm using 1969 Chevy single piston front calipers and 57-64 Olds rear drum brakes. The master cylinder is mounted 24"-30" higher than the calipers and wheel cylinders. Do I need to use residual pressure valves?
Thanks!
