-   -   Do I need residual pressure valves? (http://www.hotrodders.com/forum/do-i-need-residual-pressure-valves-200639.html)
1930u 06-19-2011 07:30 PM
To all- My Corvette style master cylinder is mounted at a right angle behind the dash. I'm using 1969 Chevy single piston front calipers and 57-64 Olds rear drum brakes. The master cylinder is mounted 24"-30" higher than the calipers and wheel cylinders. Do I need to use residual pressure valves?
Thanks!
evolvo 06-19-2011 10:32 PM
No you don't
Irelands child 06-20-2011 05:20 AM
You do not need the residual valves but will probably need a proportioning valve and possibly a hold off valve to balance the brake application pressures. Speedway, Summit, Jegs have both (who said this was simple :pain: )
1930u 06-21-2011 07:58 PM
Thanks guy's. I am using a proportioning valve.
aosborn 06-24-2011 09:38 AM
You will also need a residual pressure valve for the rear axle drum brakes. A 10lb unit can be installed inline.
Andy
