Do I need residual pressure valves? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2011, 07:30 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
To all- My Corvette style master cylinder is mounted at a right angle behind the dash. I'm using 1969 Chevy single piston front calipers and 57-64 Olds rear drum brakes. The master cylinder is mounted 24"-30" higher than the calipers and wheel cylinders. Do I need to use residual pressure valves?
Thanks!
Old 06-19-2011, 10:32 PM
evolvo's Avatar
Heathen
No you don't
Old 06-20-2011, 05:20 AM
Irelands child's Avatar
You do not need the residual valves but will probably need a proportioning valve and possibly a hold off valve to balance the brake application pressures. Speedway, Summit, Jegs have both (who said this was simple )
Irelands child
Old 06-21-2011, 07:58 PM
1930u's Avatar
Thanks guy's. I am using a proportioning valve.
Old 06-24-2011, 09:38 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
You will also need a residual pressure valve for the rear axle drum brakes. A 10lb unit can be installed inline.
Andy
Residual check valves Migman Suspension - Brakes - Steering 20 03-09-2010 10:27 PM
How many residual pressure valves? Chumley360 Suspension - Brakes - Steering 5 04-07-2009 01:47 PM
Dual M/C for '55 Ford & Residual Valves Sweet-34 Suspension - Brakes - Steering 5 07-18-2008 06:46 AM
RESIDUAL VALVES, for MC below WC. hotrod389 Suspension - Brakes - Steering 8 08-19-2006 05:14 AM
Help installing residual valves upthcreek Suspension - Brakes - Steering 4 02-01-2006 04:03 PM
