do i need screw in studs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2006, 05:28 PM
I have a set of valve springs that i had bought for another engine but they may be more useful to the engine that i am working on now. Not sure of cam lift but it is an RV cam. Spring pressures are 1.700 / 105 psi, 1.200 / 296 psi. I will be nowhere near that open height. do i need to pull the heads and get screw in studs? will the stock valvetrain hold out? If I don't need screw in studs what is the threshold where one would need to install screw in studs?
Old 05-04-2006, 09:12 PM
GoneNova/406's Avatar
if you had .500 lift and possibly 1.6 rockers you would then want them.
Old 05-04-2006, 09:17 PM
black66's Avatar
www.airriderz.com
screw in studs
I am running .640 lift on a SBC 355 with 1.6 rockers. AFR recommended head bolts over screw in studs for my new AFR 195 comp heads.....
Dave
Old 05-04-2006, 09:21 PM
thanks for the replys, I will put em in this weekend. If it wasn't for the experience of so many on this site, even for such a novice question, my truck would have hand grenaded by now for sure.
Screw in studs 83c10 Engine 3 04-03-2005 01:07 PM
Screw in studs needed? granprix76 Engine 1 11-05-2004 12:14 PM
how much $ normally for machineing for screw in studs? Dubz Engine 30 04-05-2004 01:20 PM
Blower Studs and Pop Off Valve camaroman7d Engine 2 03-03-2004 03:48 PM
screw in studs on heads ? inkfixer73 Engine 2 10-06-2003 10:07 AM
