Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - do i need sealer
Old 07-04-2013, 08:13 PM
carolinacustoms's Avatar
carolinacustoms carolinacustoms is offline
Automotive Extraordinaire
Originally Posted by 69 widetrack View Post
As much as Kelly's advice is sound, it all boils down to substrate. If your substrate is solid, consistent and compatable to your top coat...ie fully cured single stage urethane, prepped with proper grit of sand paper (600 wet, 400 dry for base coat) sealer is not required.
Look at it this way, if a body shop is doing a spot repair on a fender and have primed the repaired damaged area with a quality 2K primer, do they seal the fender? NO...the sealer would cover the color in the blend area not allowing for a blend of color. Sealer is meant to give the vehicle being painted a uniform substrate, if you have a uniform substrate....why seal it? It's just another product that costs money, keeps you in the paint booth longer and gives you more opportunity to get dirt or whatever other imperfections that might occur in your new paint job.
Hope this helps.
Ray
Good information Ray. I took for granted he was painting the entire car from his post, but I should have elaborated more as you did. Thanks for reading my mind and posting what I was thinking .
Kelly
