At full throttle while braking on the line or at speed?
A converter with around 2000-2500rpm stall is normally used with a cam like yours. A 383 likes more carb than 600cfm. Brain Fart on stall rpm.
You likely have issues w/the tune. I'd be looking at the carb and ignition curve. Carb: Linkage adjustment- getting WOT when the pedal- not linkage at carb- is depressed. Have someone hold the accelerator pedal to the floor and see if there's any travel left at the carb, 2'ndary opening too late, too lean, too rich, wrong power valve or piston enrichment setting, are just a couple things to check. Ignition curve: Do a quick search, there are dozens of run-down's on this no need to rehash it all now, at least until you check the carb over. Basically, see that you do have about 34-36 degrees TOTAL to start with. EDIT- This isn't to say that a higher than stock stall TC won't help you- it will. It just won't help w/the problem you describe. It will allow the engine to get into the fat part of the torque curve at launch. That's what a high stall TC does, besides heat up the fluid. If you get a higher than stock stall TC, get a cooler along w/it.
Bog
Someone give cobalt327 a medal!!! The engine was running lean, I put the pump rod in the closest hole on the pump arm to give a huge shot of fuel and got rid of my problem!! THANKS A MILLION!!!
Caleb |
| B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? | zbhover | Transmission - Rearend | 2 | 11-02-2008 07:52 PM |
| How 'bout a 3400 stall converter? | Sixtyninemercury | Transmission - Rearend | 4 | 09-12-2008 12:53 PM |
| stall converter | adam15425 | Engine | 26 | 10-15-2004 05:50 PM |
| Torque converter ??? | blacklotus | Transmission - Rearend | 2 | 10-12-2004 02:23 PM |
| Is my jeg's brand torque converter a dud? | elukas | Transmission - Rearend | 5 | 10-07-2004 11:08 AM |
