do I need to tub? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2011, 08:19 AM
do I need to tub?
I just bought a Ford 9 inch housing at Iola car show. it is 51 inches flange to flange. To put it in my 1990 Camaro RS would I need to tub the vehicle ?
Old 07-11-2011, 12:46 PM
35terraplane's Avatar
Tub
How wide is the frame, what size tires are you going to use, how wide is it from inside the lip of fender to lip of fender.
Bob
Old 07-11-2011, 06:34 PM
do i need to tub
35terraplane, my frame is 43 inches wide outside to outside. My tires are 295/50R/15 . lip to lip is 69 inches wide from side to side . unless you mean just the lip. frame to outside of lip is 12 inches,,,,, inside lip to outside of lip is 1/2 inch. I hope this makes sense to you. thanks for being patient !
Last edited by torquemonster; 07-11-2011 at 06:41 PM. Reason: not sure what it means
Old 07-12-2011, 08:19 AM
Tub
Make sense, I forgot to ask how wide are the tires, that would be at the widest point. From the sound of it you only have 11 1/2" from inside lip to frame. How wide is the rearend you have now, more than likely not much wider than your frame. The new one is four inches wider than your frame on each side, I think you might have to narrow the rearend and axles. You can play with wheel offsets but I don't think that will do it.
Bob
