Do I need to turn or polish my crank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2008, 09:29 PM
DaSouthWon's Avatar
I put up the tools against$300
A friend of mine just gave me the rotating assembly out of a ford racing crate motor he purchased and turned into a 331. He put about 15k miles on the original assembly before pulling it out. After going over the crank most of the journals are still smooth but a few have some small scratches from wear. None of the scratches are really large enough to catch a thumbnail in but their not perfectly smooth either. How do I know when I can get away with just polishing the crank and when do I need to turn the crank? I will obviously replace the bearings, but I would like to get away with not having the crank turned if possible.
The Following User Says Thank You to DaSouthWon For This Useful Post:
markhansenconquest (02-24-2014)
Old 07-21-2008, 09:43 PM
mic the crank, if it mics good, clean and polish, mic again. small scatches won't cause any problems.
sam-missle
The Following User Says Thank You to sam-missle For This Useful Post:
Old 07-21-2008, 10:13 PM
mic the crank
Couldn't be said better.
ALWAYS MEASURE!
ALWAYS CHECK - EVERYTHING.
The Following User Says Thank You to Stroke For This Useful Post:
Old 07-21-2008, 10:20 PM
DaSouthWon's Avatar
whats an ok bearing clearance on a ford small block?
Old 07-22-2008, 07:52 AM
Marcel
Last journal entry: Choo-choo town
polishing a crank
If it mic's OK, I polish my with large brown paper grocerey bag strips (if you can find a brown paper bag now days. Just cut it into strips narrower than the throes of the crank. I have remover-ed small rust spots that aren't bad with it.
The Following User Says Thank You to lanierledford For This Useful Post:
Old 07-22-2008, 08:01 AM
SSedan64's Avatar
An old leather belt works great for polishing too.
The Following User Says Thank You to SSedan64 For This Useful Post:
Old 07-22-2008, 09:04 AM
Da south,
do check out the Knowledge Base link at the top of the page for any motor's specs....
ex:
http://www.hotrodders.com/kb/ford-engine-tech
The Following User Says Thank You to red65mustang For This Useful Post:
Old 07-23-2008, 12:41 AM
DaSouthWon's Avatar
Ok, I looked in the knowledge base and have done a good bit of searching looking for wear specs, or tolerances on a sbf and I cant really find much. I can find the original part specs, but can't find anything that says what wear is within normal specs and what is excessive and must be replaced. Can anyone guide me in the right direction?
Old 07-23-2008, 05:01 AM
techinspector1's Avatar
Wiki Edits: 326
For a street motor.....
0.001"/0.002" on the rods, shoot for 0.0015"
0.0015"/0.0025" on the mains, shoot for 0.002"
The Following User Says Thank You to techinspector1 For This Useful Post:
Old 02-24-2014, 11:38 PM
thanks to all who replyed ....
has anyone tried a ruby stone or a arkanasaw stone to micro polish minor imperfections too small for your finger nail to catch and my crank is nitrited on mains and journals I like the paper bag thing and the leather belt thing. I found out about this site from a friend that I met in a post. those stones are used by mold makers and tool makers to polish mold parts. Im a tool maker 32 years trying to do things by my self if I can . thanks again for all who take time to talk to me and share there knowledge.........
78 camaro turn signal help hcker2000 Electrical 16 06-15-2007 05:06 PM
turn my engine backup to get the power i had koop Engine 1 05-01-2007 12:04 PM
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 11:01 AM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 07:23 PM
Rebuilt engine won't crank. lt1bbody Engine 10 04-22-2005 01:44 PM
