Do I need the vacuum modulator? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2004, 04:36 PM
65 streeter's Avatar
New Member
Hey Gang,
With the vacuum modulator hooked up it seems to shift to early.. especially from 2nd to 3rd. I'm going to adjust the modulator but I ran it with the vacuum disconnected and liked the shift points unconnected. Here is the goop:
Just put in 3.73's, TH350 tranny with TCI 3000 stall 10 in converter, motor is a 350 cid with above 420 horses (Edelbrock performer rpm set-up). I have the KD cable adjusted right as it kicks down nice.
I don't know how it should all feel as it is all a new set-up to me.
Thanks
Old 07-02-2004, 09:44 PM
DoubleVision's Avatar
I would use it, as for shift points, after you adjust the modulator, if the shift points still aren`t to your happiness get a adjustable govenor kit. you can taylor your upper rpm shift points with it.
Old 07-02-2004, 11:37 PM
New Member
I adjusted the modulator and it helped. I'm only getting about 8 or 9 hg's in drive (idle at 800/900) because of the cam... I'm thinking that is a contributor. It is an Art Carr tranny that I picked up from a friend who had low miles on it (he is going with a 200R4).
I read another post about low vacuum modulators that are available and I may try that. I'd like to read up on the adjustable governor kit... where would I find that?
Please note... I am not a tranny guy. Appreciate the help.
Old 07-03-2004, 11:20 PM
New Member
Well I was playing with the speedo gear and yep, dropped it inside. So took the rear housing off and much to my surprise I found a plastic tooth missing from the governor drive. So I'm taking the old governer, which shifted where I wanted it, and putting it in it's place. I'm also going to swap the speedo drive gears.
Does anyone know the trick to getting the speedo drive gear clip to let go my eggo? Don't want to break nothin.
Just found another post archive that stated how the clip works. So looks like I have to hold the tips of the clip down and gently knock the gear off.
Just found this post:
th350 Speedometer problem
It helped. Hopefully I'm okay to tap the gear loose as it won't move by hand.
Old 07-04-2004, 02:03 PM
New Member
Changed the governor and the speedo gears... runs great, shifts where I want it and the speedo seems accurate... life is good!
