Do more coats of clear..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2005, 04:37 PM
Do more coats of clear add to depth, gloss and shine? If two is good is four better and six great?
Old 04-08-2005, 04:51 PM
BarryK's Avatar
No you cannot make that blanket statement!
Some clears will peak out at 2-4 coats as far as depth and gloss the reason is clarity depends on the resin used and the type or brands of UV blockers added. So you could put 10 coats on and you really would not gain 5-10 percent at best.
No matter what clear you spray for custom work (best, good, bad) you should never apply more than three coats a day. This will allow the solvents to get out and the clear will cure better and have more clarity (depth) when you are done.
Depth + Clarity =Gloss
Old 04-08-2005, 08:30 PM
That's what I figured. Thanks Barry.
Clear, No Clear, or Clear + Base? tallpaul Body - Exterior 16 01-21-2006 05:30 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 02:52 PM
The clear test. BarryK Body - Exterior 55 03-25-2005 09:40 AM
Painting and Clear with PPG, what do I do next?????? harrija5 Body - Exterior 16 02-03-2005 08:50 PM
Time between Clear coats TurboS10 Body - Exterior 11 11-23-2002 04:55 AM
