Do my spring have an upper/lower end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2006, 07:40 AM
Grogetter's Avatar
I had to take the rear end out of my Malibu and found that the pigtails on each end of the coil springs had different shapes. On each spring, one of the pigtails forms a nice round opening and the other end pigtail is somewhat oblong. Do these springs have a "top" and "bottom"?
Thanks
Donny
Old 09-29-2006, 10:01 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Yep, ONe of those ends will fit the spring bucket properly. Look closely and you will see.
Old 10-01-2006, 06:26 AM
Grogetter's Avatar
Spring question update
Mike at Eaton Springs tells me that the difference in the pigtails is simply a result of the manufacturing process and makes no difference in the fit or performance of the spring.
Just an FYI
Old 10-02-2006, 01:48 PM
So both ends are closed?
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 07:29 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
8.5" 10-bolt coil spring rear end Kieran Transmission - Rearend 3 04-28-2003 03:24 PM
Ring End Gap bpd411 Engine 3 02-26-2003 09:19 AM
