Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-28-2006, 07:17 PM
SCHOONER SCHOONER is offline
DO THEY MAKE "CYLINDER HEAD BRASS FREEZE PLUGS ?
Hi Guys
Got this pain in the butt situation.
I replaced the STEEL FREEZE PLUGS that were placed in the body of my motor mistakely by my machine shop. WITH BRASS ONES.
After reading (maybe that my problem ) The reading said, "... Brass Freeze Plugs last LONGER than STEEL."
My problem is: I CAN'T FINE BRASS FREEZE PLUGS FOR THE HEADS
Presently, Steel Freeze Plugs are DEEP SET ONES in the Cylinder Heads.
The Brass body plugs I are shallow around the rims. The Steel ones in the head have a DEEPER RIM that set into the heard DEEPER.
Any you guys can figure-out this pain in the butt problem for me PLEASE.
WHERE ON EARTH CAN I BUY THOSE DAMN 'DEEP SET RASS FREEZE HEAD PLUGS" for my 289 engine
Thanks guys
GOD BLESS YOU ALL
Schooner
Old 10-28-2006, 07:21 PM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 5
re: DO THEY MAKE "CYLINDER HEAD BRASS FREEZE PLUGS ?
"The Brass body plugs I are shallow around the rims. The Steel ones in the head have a DEEPER RIM that set into the heard DEEPER."
Why would this be a problem.......?
As long as they seal the hole, I don't see a problem. Use whatever you can get....Brass may last longer, but the steel will probably outlast the engine.
Old 10-28-2006, 08:12 PM
Greg Latvala's Avatar
Greg Latvala Greg Latvala is offline
Pioneer Barnes, Dorman, US Tool, are 3 suppliers of cup plugs.
Could look it up on Monday if need be.
Also see you live in Las Vegas(pretty big city) if you cant find a machine shop there that can come up with correct part number I dont know what to do.
Is this a small block Ford?
Old 10-28-2006, 08:16 PM
scholman scholman is offline
SCHOONER,
The "shallow cup" will work just fine the head. Pound it in and get it running again.
Scholman
Old 10-29-2006, 08:59 AM
machine shop tom's Avatar
machine shop tom machine shop tom is offline
ASE-Certified Master Machinist
Dorman (Motormite) part #565-028 (deep 1-1/2"), 565-077 (shallow 1-1/2"), both brass plug numbers.
tom
Ya cain't fix stoopid, but ya kin TAX it!
Old 10-29-2006, 04:54 PM
cab cab is offline
If you are concerned about rust you could scuff and paint the freeze plug (inside and out) with engine enamel - just make sure you wipe any paint off the "sides" of the plug before you pound it in.
Old 10-29-2006, 06:57 PM
Hey Poncho62
What the problem is; There's a reason why those head freeze plug are deep set. Other wise they would have put in the shallow ones. There's a reason for everything in this world. That's why?
I don't mean to be short with you. I'm just kinda talkin' to myself and sharing it with.
Thank you for your impute
GOD BLESS
Schooner
Old 10-29-2006, 07:01 PM
Hey Guy
YES, its a 289 Mustang engine.
If the machine shop has the deep set plugs, then why can't I get 'em from auto part suppliers?
Thanks for you impute.
GOD BLESS
Schooner
Old 10-29-2006, 09:09 PM
All 289 and 302 had the shallow plugs in there from factory. When you put them in be sure to get them past the little chamfered area. If one pups out that wont be too good for your engine.
I used to put the deep ones in because thats all I was given to use (didnt know any better either), theres still room for water to flow inside. The deep plugs will not come out easy like the shallow ones did.
Now I would want to do it right find the shallow cup plugs.
Old 10-29-2006, 09:25 PM
Hey Greg
I replaced the steel freeze plugs with; BRASS ONES.
And yes I did bang 'em in pass the champed part around the openning.
However, what I'm talking about is: Replacing those darn Cyliinder Head Steel Plugs with BRASS ONE. These C/H/Plugs have an 7/16" rim around them and the plug sits into the head deeply. Not like the ones on the block.
My problem is I want to replace those suckers with: BRASS ONES. But I haven't found the DEEP SET BRASS ONES WITH THE 7/16ths. in. rim that go deep into the heads.
My search continues, help if you can in locating a supplier that has those darn Brass Head Plugs.
Thanks
GOD BLESS
Schooner
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "DO THEY MAKE "CYLINDER HEAD BRASS FREEZE PLUGS ?"
Method to determine carburator CFM? jpd37 Engine 68 10-29-2006 09:55 AM
tip of the day #13.999 ahh heck, lets just make it 14 kenseth17 Body - Exterior 1 09-30-2005 01:24 PM
SBO 350, Head Gasket help, with photos 360Camaro Engine 5 07-11-2005 08:29 PM
blown head gasket - need help to make choices dbuff Engine 4 08-16-2004 01:05 PM
Rant: Bosch Plugs Cost me $300.00 Rolm Engine 7 07-22-2004 09:50 PM
