Do they make a shorter yoke on the 9" ford differential, or trans yoke - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2009, 10:28 AM
We have a 32 Ford under construction. We have moved the rear end back to visually center it in the rear fenders. Previously we moved the motor back 1" to clear an electric fan.
Our problem is that the net result to the driveshaft is that it is too long.
We have only 1/4" slip yoke travel, rather than the normal 3/4". Rather than shorten the driveshaft, do they make a shorter pinion yoke for the 9" Ford differential. Ours is approximately 3 1/8 from the split of the universal to the front of the external slinger. Is there a shorter one available?
If not a shorter pinion yoke, what about a shorter driveshaft transmission slip yoke for the 350 turbo?
Old 07-16-2009, 11:58 AM
9in yokes
there are a number of lengths, i have 2 the 1 i use is aprox 2in shorter than the other. search the junk yards. sorry to hear the non ford power being used,my 32 is all henry good luck cliff
Old 07-16-2009, 12:05 PM
powerrodsmike's Avatar
Wiki Edits: 161
This one might work for you.
http://www.speedwaymotors.com/9-Inch...Yoke,1285.html
Later, mikey
BE different....ACT normal.
Old 07-16-2009, 12:30 PM
prostreet6t9's Avatar
Differential/Driveline
I think the speedway link is the Neapco yoke Part# N2-4-FD01X. The Yoke should be 4" O/A length.
Old 07-17-2009, 09:57 AM
S10xGN's Avatar
Gotta love a turbo!
It costs $75.00 here to get a shaft shortened, why risk trashing the rear end swapping pinion yokes? If cost is that big a concern, try junkyarding for a shorter one...
Russ
AXOD Ford trans rebuild advice. 4 Jaw Chuck Transmission - Rearend 22 03-16-2004 06:37 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
ford 9" rear beetle9 Transmission - Rearend 12 10-27-2002 06:57 AM
Ford Engine To Trans Help davesr Engine 1 01-05-2002 09:27 AM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 10:15 AM
