do u use line lock with a trans brake? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2010, 09:44 PM
AceRacing 79 mustang's Avatar
I am looking to find out what I need to drag race my mustang is there some one out there that would be able to tell me what is a good set up
Old 10-23-2010, 09:59 PM
big gear head's Avatar
High Performance Rear Ends
Yes, you use the line lock for the burnout and the trans brake to hold it on the line.
Old 10-25-2010, 07:55 PM
thanks I have a line lock set up I jut need to install it and I am looking to git a trans brake set up or a trans with one in it I have been looking at summit's web site. but if you know of a place that has them at a good price let me know thanks
Old 10-25-2010, 08:49 PM
You might check with jakeshoe.
Old 10-26-2010, 12:58 AM
SSedan64's Avatar
Ace, what Trans are you using in the Stang?
Old 10-26-2010, 07:14 PM
I think it is a c4 it is a 3 speed auto but I do not know for shure I am new to the auto tran's I all way's had stick's. I would like to try to find out what gear's the rear end has in it is there a way to figure it out? counting teeth or numbers on the gear's ? I have not had the cover off yet but it has some big tires on it 26/11.5/15 mickey thompson ET streets
Old 10-26-2010, 08:13 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
be advised the trans must be properly set up for trans brake use. Each trans and transbrake manufacturer may require different setup. Some are simple , others are not
Old 10-27-2010, 07:33 PM
thanks
I will have to look in to it!
Anyone ever had a line lock fail and degrade braking? sizemoremk Suspension - Brakes - Steering 7 09-22-2006 02:13 PM
Caddy Brake Fun & Does Line Size Matter? Help Needed. bigfred1958 Suspension - Brakes - Steering 5 04-06-2006 08:20 AM
trans brake wes Transmission - Rearend 1 07-11-2005 09:40 AM
brake line plumbing..help RodFather Suspension - Brakes - Steering 8 07-11-2005 07:06 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
