Do you need to bleed both sides of a 4 port master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2003, 03:59 AM
Post Do you need to bleed both sides of a 4 port master cylinder
My new MC has 4 ports on it. Do i need to bench bleed all 4 sides or just the 2 i will be using?
Old 03-22-2003, 04:45 AM
milner's Avatar
Post
you only need to bleed the two, you are using.
Old 03-23-2003, 11:30 PM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
Post
Milner is right. The air will be expelled from either side. I never bench bleed if it is a new system and all is dry. Only bench bleed if I am only changing a bad MC. Then don't have to bleed all the lines. I use a pressure bleeder or a Phoenix bleed tool on a new system but a helper works ok too.
