Do you NEED a thermostat? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 10-23-2005, 01:51 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by docvette
Doc here,
In the beginning...There was Ford..Henry looked down upon his flock and said:
It was good..but shall be better..
The Model T had no thermostat in it..and a water jacket you could put your fist into..and a pump you could steer the QE II with...A big Brass radiator that ould stop a 30 cal bullet..freeze plugs that were doorknob sized...
what happened mostly on long hauls, traffic and hills? It blew steam and overheated max! because hot became hotter...and cold stayed that way for a long time! It was good enough for the day..but today doesn't cut it..It wasn't until they went to thermostats did it get better..(I have no idea what year that was..guessing 29 V8 60 flattie..)
Never knew the industry to manufacture and install ANYTHING they couldn't live without..to appease the Beancounters..
And Henry looked Upon his Factory..and it was good..on the 7 th day ... he invented the Car salesman...
Doc
The only 2 things that are missing is........
1) An engine produces XX amount of heat at any given point.. That still has to be exchanged to maintain a constant operating temperature.
2) those old radiators are ineffiecient. Thicker metal takes more time to transfer the heat to the air...... like over porting a cylinder head, or overboring the cylinder walls too thin..... think about it.
3) look at the airflow on those Ts.
If you don't watch out you will fall into that decades old tale that too large of a radiator will make an engine run hot. I have asked many experts if they ever saw a boat with a car engine. Does it overheat because the lake is too big??????
I have been running 195 * thermostats in everything since the early 60s....never had any problems.
  #32 (permalink)
Old 10-23-2005, 02:22 PM
Classix_Lover's Avatar
Music soothes the soul
Last journal entry: Wiring finished finally
Haha, I remember arguing a while back about the whole overheating process but I'll just give you a simple answer not regarding that. You don't HAVE to run a thermostat in your motor, simple as that but I would not recommend it. A thermostat keeps a nice semi-constant operating temperature for your motor assuming your cooling system's up to the challenge. Problem's with running no thermostat is obviously that if your cooling system's too effective, than your motor might operate, lets just say at 160* when you might want to run it at 185*. Obviously not an ideal temperature to run at and not exactly a "good" plan if you want to hang on to your motor for a long time. If you have an overheating problem, thermostats can help delay it slightly but overheating will be inevitable. I still dunno where I stand on the whole "flowing too fast" issue. Both sides have good points so I'm just kind of in the middle on this right now but we'll see who changes my mind .
  #33 (permalink)
Old 10-23-2005, 05:05 PM
coldknock's Avatar
Don't forget about cavitation. With little to no pressure differential before and after the impeller the water, sometimes, will spin in a circle with the impeller and not cool a cotton pickin' thing. One more reason to have a thermostat in place.
Larry
  #34 (permalink)
Old 10-24-2005, 07:59 AM
thenige's Avatar
New Member
I've actually just read up on this subject myself since I'm moving to an electric motor-driven water pump and was wondering if I needed a thermostat since I can control the water pump operation via a switch.
Some history..
Back in the 55-57 Chevys if the thermostat was removed from these cars the engine would actually overheat.
Original thoughts were that the coolant was moving through the engine too quickly to provide proper cooling.
The actual problem was that when you remove the thermostat from a cooling system with a vertical radiator, the point of highest pressure moves to the radiator. That said, the excess pressure was higher than the capacity of the radiator cap spring, and coolant would escape.
So in my view, if you must run without a thermostat, make sure you have a cap rated at higher than stock psi.
Now if your more serious about cooling, you can modify the water pump housing which has a bypass to avoid pressure buildup when the thermostat is closed (assuming you have one).
What you do is plug the bypass and drill 4 holes (.200 for 160F thermostat or .080 for a 180F thermostat). This will improve block filling since air in the waterjackets has a place to escape. The four holes and plugging the bypass usually results in a measurable drop in coolant temp. This depends on your heads and water pump (racing heads and pumps often change the flow).
Regards,
Nigel
  #35 (permalink)
Old 11-17-2005, 12:45 PM
up untill recently i didnt know how i stood on this matter... but yea you can run with out a T-stat and yeah when its cold its cold then finally when it heats up and your going 65 mph for some time its gets hot and when its hot danm is it hot... so ill be putting a t-stat back in soon. Too fast of a flow with out it ?? who knows but i hope one day some one can engineer a more effiecinet way of cooling other than water jackets , rubber hoses, t-stats, iron propeller belt driven pumps, blocked Rads by comfortable A/C condersors and hi psi rad caps.... Im just saying tho
  #36 (permalink)
Old 11-17-2005, 07:15 PM
Wiki Edits: 31
yes a thermostat is needed, in a street vehicle, especially in new vehicles because of emissions. The thermostat stays closed until operating temp, when it opens, it closes off the link to the radiator when closed, but there is always a bypass to the water pump to keep water circulating in the engine itself, keeping temps uniform with no hot spots, once open ( a small block chevy 180 will be fully open at 190-195 degrees, a 195 ( new car ) would be fully open around 212 degrees ). The thermostat allows the coolant in the radiator to cool off, and the coolant in the engine to absorb the heat from combustion, until the thermostat rating when it all starts over again, a thermostat keeps the engine in a operating temp range, to run efficently. a engine running too cold will produce HC's and Co's and would fail a emmisions test, and will be inneficent, a engine at the proper operating temp will be efficent and won't produce as many HC's and Co's.
  #37 (permalink)
Old 11-17-2005, 07:25 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
thermostate
yes.............. hell yes...................a thousand times YES
  #38 (permalink)
Old 11-17-2005, 07:55 PM
black66's Avatar
www.airriderz.com
Originally Posted by Tech @ BG
No myth here! No thermostat, and you will run hotter than running say a 160.
You need something to keep the water in the engine long enough to pull the heat out of the engine. This is why the thermostat opens when it gets to temp, and flows back into the radiator to cool off. It doesn't have to be a thermostat, you can put a restrictor in place to control water flow. This is done on most race engines.
Regardless of how you do it, you want to control engine temp weather your computer controlled this will give you your best power, and life out of your engine.
BG Tech is correct. I run a 160 in the summer. Car never get past 195 even in the hottest days or worst bumber to bumber cruises. And I am running a 530 HP small block.
I tried a 195 thermostat this summer and I was running 205-210 on really hot days or crusing...
Electric water pumps are good for racing. But will not compete with a good mechanical high flow pump. Been there done that.....
  #39 (permalink)
Old 11-17-2005, 09:21 PM
Originally Posted by xntrik
About the only facts in this whole thread can be found at this link provided by xntrk
  #40 (permalink)
Old 11-18-2005, 08:07 AM
I agree 100%. That's what I've always believed to be true.
There are a lot of myths floating around, like the one about hot water freezing before cold water. oops, I probably shouldn't have said that
  #41 (permalink)
Old 11-18-2005, 08:31 AM
Technical Support Barry Grant
Since this has been brought back up I've got a question for those that may know. Since they're saying it's totally based on pressure not time, I'm confused since I've seen a difference. On one of my boats it has an open cooling system (picks water up from the lake goes strait through the engine, and back out into the lake) at idle it runs about 15 PSI water pressure. Normally about 155 degrees water temp once it finally warms up with a 160 thermostat with four 3/16" holes in it. At high speed I can get over 40 PSI in the engine. I would think this should be enough to get to all of the "hot spots" in the engine. I can control the top end water pressure with a relief valve. I took the thermostat out completely, and the engine ran hotter. Still the same 40 PSI in the engine. Now to me this would probe that the water needs to stay in the engine a little longer to transmit hit. Now I realize this test was not empirical, because I didn't measure the GPM water flow before and after, but am I missing something?
  #42 (permalink)
Old 11-18-2005, 09:05 AM
love his logic, remove the cat's= more HP,
so remove the thermostat=more hp?
"if ain't broke don't fix it(by removing it)!"
  #43 (permalink)
Old 11-18-2005, 09:08 AM
"if ain't broke don't fix it!"
Na, I actually wanted to try it to verify what was going on within this thread when it first came up. I put the thermostat back in after the second run, the engine temp was getting hotter than I felt comfortable with.
  #44 (permalink)
Old 11-18-2005, 09:36 AM
You said the water temp is 155*with a thermostat and that engine ran hotter without the thermostat. I'm assuming we are talking about water temps being hotter, not metal temps? By my way of thinking, the cooling system must be more efficient without the stat. The more heat that is transferred from the engine to the coolant the HIGHER the water temps should be. Assuming that the amount of heat that the engine produces is a constant value, the only way the water can be hotter is for the engine (metal) to be cooler, thus greater efficiency. I would think this to be especially true in an open system as long as the lake temps are constant.
  #45 (permalink)
Old 11-18-2005, 09:41 AM
Dirt Car 18,
Actually the water temp was up about 35 degrees, as was the block temp (via infared after a run) and oil temp up almost 25 degrees if I remember correctly I'll have to double check my notes. As soon as I put it back in everything went back to normal. In my mind that's telling me I was hotter.
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 01:29 PM
Adjustable Fan Thermostat Working in Reverse JohnTN Electrical 2 04-08-2005 12:43 PM
Electric fan thermostat Novaman78 Engine 4 01-27-2005 02:32 AM
Thermostat questions flyfisher Engine 5 09-29-2004 02:21 PM
thermostat crshrmn3 Engine 7 10-01-2003 07:27 PM
