Do you NEED a thermostat? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 11-18-2005, 10:07 AM
montea's Avatar
tryn to learn
i read on here before that it was better to run without a thermostat (gutted one) because it runs cooler and wont over heat.. i tried it on my SBC and yeah it does run cooler and takes forever to reach operating temp. never over heated, just wasnt able to get warmed up. cold engine = more wear. i dont see the point, so i installed a 180-190 stat and it stays constantly at 190 degrees after its warm wich doesnt take to long.
i will always run a thermostat now.
If you are going to run without one and have your car run cold and create more wear, the same time why not use some real cheap low grade no name motor oil
  #47 (permalink)
Old 11-18-2005, 11:03 AM
Originally Posted by Tech @ BG
Dirt Car 18,
Actually the water temp was up about 35 degrees, as was the block temp (via infared after a run) and oil temp up almost 25 degrees if I remember correctly I'll have to double check my notes. As soon as I put it back in everything went back to normal. In my mind that's telling me I was hotter.
with no restriction even withe pressure the rapid flow would likely act as a syphen and creat spots of air or steam in the engine causing hot spots and many other problems down the lake.with raw watter cooling ther ar many differences than a radiator, the angle of the engine .watercooled exaust versus dry. in versus out of watter flowetce. cliff
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 01:29 PM
Adjustable Fan Thermostat Working in Reverse JohnTN Electrical 2 04-08-2005 12:43 PM
Electric fan thermostat Novaman78 Engine 4 01-27-2005 02:32 AM
Thermostat questions flyfisher Engine 5 09-29-2004 02:21 PM
thermostat crshrmn3 Engine 7 10-01-2003 07:27 PM
