Do you need a transmission to start an engine ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2013, 10:45 AM
WITHOUT !! the automatic transmission attached, I tried starting my truck, to check for leaks, but It will not start.
Is there a way to do it. IF possible ?
its on a 2002 Suburban 5.3 V8 with a 4l60e
Old 09-16-2013, 10:38 AM
Yes its possible, but the ECM will need to know that the trans is in either neutral or park. This owuld be accomplished by positioning the shifter position switch in the neutral or park position. It is niormally located in that black plastic box on the side of teh transmission. Take that off the trans, plug it into the proper connector, then turn the switch until theengine turns over.
You would of course need a flexplate or flywheel in place to turn teh engine over using the starter.
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
V8Truck (09-16-2013)
Old 09-16-2013, 09:40 PM
Thanks for that Hogg
seems clear and straight forward.
It's good someone on the trans & rearend forum knows enough about automatic trannies and their relation to engines to clearly answer this question.
help, engine will not start defilade Engine 11 12-27-2010 02:07 PM
95 ford F-150 engine swap, Same Transmission fit new engine? F-150 Transmission - Rearend 5 10-07-2007 01:11 PM
Remote Start-Manual Transmission Barrybomb Electrical 1 07-29-2007 12:58 PM
My Fresh Engine and Transmission|When Can I Start Hammering This Thing? Ghetto Jet Engine 20 03-16-2005 08:29 AM
engine start up 406camaro Introduce Yourself 1 11-27-2004 09:06 PM
