We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 04-16-2009, 05:51 PM
powerhunter powerhunter is offline
powerhunter's barnstar
Wiki editor
Last wiki edit: Hi,im building a 355 with 10.8-1 compressio
Wiki Edits: 3
Do you need to use ring compressors?
Hi ,just wondering if I have to buy a ring compressor to install my piston and ring assemblies into my block?Or if I can just do it by hand?
Old 04-16-2009, 06:29 PM
crussell85 crussell85 is offline
if you think you don't need a ring compressor for installing pistons should you really be building an engine. Go spend 10 bucks and buy a ring compressor. how would you do them without one.
Old 04-16-2009, 06:52 PM
Holder350's Avatar
Holder350 Holder350 is offline
Auto Parts Professional
You "-CAN-" put pistons in their holes without one, but you run a BIG risk of breaking a ring and oil rings are almost impossible to get in.
Make it easy on yourself and go buy one, they come in handy....
Old 04-16-2009, 07:10 PM
cobalt327's Avatar
WFO
cobalt327's barnstar
Wiki editor
Last wiki edit: Chevrolet restoration packets
Wiki Edits: 20
Thousands of engines have been built using nothing more than an over-sized hose clamp.
But, yeah, get a compressor. There's no need to make things any harder than they need to be.
Be aware there are different styles, and they cost form a few dollars to quite a bit.
The old, steel sheet coiled w/a tensioning device was used for years by many mechanics. These are relatively cheap, but can be a bit of a beach to use for a beginner.
There are dedicated bore size "compressors" that are basically a tapered ring of the same size as the bore that will compress the rings as the piston is slid into the bore. Generally, these are the easiest to use. Down side is they are a little high, price-wise and only fit one bore size correctly.
Then there are "pliers-type" compressors. They generally work well after being properly adjusted. Cost a bit more, but can be used on a variety of bore sizes.
Don't forget to use a couple pieces of fuel hose over the rod bolts to protect the bores from getting nicked. You can also buy these sleeves made for the purpose.
Old 04-16-2009, 07:13 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
eloc431962's barnstar
Wiki editor
Wiki Edits: 18
make the investment.its a small price to pay to do something right.good luck on your build. . cole
Old 04-16-2009, 10:15 PM
Wiki editor
Wiki Edits: 3
Thanks guys,I appreciate the advise.This is my first build I hope I don't screw up.
Old 04-17-2009, 07:28 AM
cobalt327's Avatar
WFO
Wiki editor
Wiki Edits: 20
The guys here on the forum are willing to help- just ask!
The only stupid question is the one you didn't ask...
Good luck.
Old 04-17-2009, 07:46 AM
dirtinla dirtinla is offline
*** Please post solutions ***
Your local auto parts store will loan you the tools for free... just leave a deposit.
-=Fred=-
Old 04-17-2009, 07:48 AM
matt167 matt167 is offline
matt167's barnstar
Wiki editor
Last wiki edit: Finding vacuum leaks
Wiki Edits: 31
if you have the right size band clamp oil filter wrench, I don't see why it wouldn't work if you got someone to hold it compressed while you tapped the pistion in
Old 04-17-2009, 08:44 AM
ap72 ap72 is online now
How fast is fast enough?
I have an adjustable hard plastic one from Total Seal- it works GREAT. I think its only like $30 too. For a highschool kid that may sound like a lot, but for an engine build its about the same amount you'll spend on sealants and such- pocket change.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Do you need to use ring compressors?"
Using the RIGHT ring compressor now! flynbrian48 Engine 4 02-18-2008 07:57 PM
Busted a bloody piston ring!!! flynbrian48 Engine 8 02-14-2008 09:28 AM
Piston ring Question (For Nitrous) Ratoflic Engine 0 04-19-2006 04:04 PM
piston help, and or ring help blake carstensen Engine 2 12-08-2005 08:25 PM
snap ring problem antiquebob Transmission - Rearend 7 04-30-2005 04:24 PM
