Do you prefer mechanical or digital odometers? - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Electric or mechanical speedometer?
Electric speedometer-LCD odometer 2 20.00%
Mechanical speedometer-Analog odometer 8 80.00%
Voters: 10. You may not vote on this poll
Old 07-09-2008, 05:14 AM
I am getting my 35 chevy project going again. I started working on the gauges. I have a gauge supplier building a quad, tach and speedo with my artwork. I was thinking of having a few sets built up since the cost is minimal once the initial tooling is done. Maybe I will recoup the investment in my own set, while allowing others to have a set of period correct looking set of gauges.
The question is, which type of speedometer do you like?
Pure analog: The odometer looks like its fits, real spinning numbers. The speedo is a little harder to calibrate. Less expensive.
Electric: The dial looks the same, but that LCD screen looks a little out of place. the electric speedometers are much easier to calibrate though. More expensive.
Thanks for your input, Each screen for each gauge is $250 so I would like to do only one.
Mark
Old 07-09-2008, 05:39 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
It might not fit your theme, but electronic all the way if you ask me. No bulky cable to route, just a couple wires. Easy to program, no changing gears (comes in handiy if you change your tire size later) The trip and odometer are combined in one window. They are expensive, but I feel they are worth it.
Old 07-09-2008, 06:33 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
My vote is for analog , the reason is simple it looks more correct. Led's are fine for a computer, I go for bulbs in tail lights and analog gages.
Cables? what cables, lights are the only wiring excluding the amp or volt meter, in fact all the sensors needed to power the digital are more cluttered and messy looking then the mechanical stuff. Is there a digital vacuum gage? not thinking so, so the choices for digital are even not that great.
For instance notice the big bulb looking sensor needed to run a temp gage, looks like a mushroom growing on top of the manifold, same for the oil pressure. I guess one could always put a big pan on top of the motor, kind of like a hat covering some guys bald head that would hide the mess. Speedo calibration easily done... that is a stretch, first think about it. How many times do you go through that, once or never, and to change a gear on a transmission is one heck fo a lot easier then working under a dash, flipping dip switches figuring out the correct combination. Easy install for a speedo digital ............. HYPE
When looking into the interior and seeing blacked out plastic squares or round dots, that's a turn off ......Butt UGLY!!! a thousand times
Old 07-09-2008, 07:06 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Hi: I'm going to move this thread to General rodding Tech, but leave it in Interior also.
Dan
Old 07-09-2008, 07:28 AM
I am old fashioned ( and old ). I prefer the mechanical cable driven units BECAUSE I know how to make them work. I also believe them to be less troublesome once you have them installed and calibrated.
I will admit that the electric ones are easier to install with the wire being easier to route than a cable.
Disclaimer :
My wife says I am stuck in 1957 when it comes to the advances of technology. I do not use electric fans on my cars. I have mechanical fuel pumps and carburetor's. I have NO computer stuff on my projects.
Deuce ...
Old 07-09-2008, 08:04 AM
Arrowhead's Avatar
Wiki Edits: 5
Originally Posted by Deuce
Disclaimer :
Deuce ...
Ha Ha
If it were up to me, EVERYTHING would be electronic.
I thoroughly regret not going EFI on my Mustang project. I miss my laptop!!!!
BTW Pepi, these are all electronic - work fine for me 3 years and 13,000 miles
Old 07-09-2008, 08:14 AM
Arrowhead's Avatar
Wiki Edits: 5
Actually, to calibrate, just push the button and hold till it's ready to calibrate, drive a meassured 2 miles, and push button agian - done!
Old 07-09-2008, 10:31 AM
pepi's Avatar
Still think the senders look like mushrooms growing all over the engine and it is looking like most prefer the analog. I am not in an argument here the question was which do you prefer and I indicated my preference and stated the reasons why. I find the analog a much more desirable set up that fits my world just fine. Digital is easy stuff and has more wiring to it just by the nature of the design .... Digital = wires, and therefore more wiring ................. common sense really...
Calibration and dip switches / single push button.......... depends on the manufacture fyi
Old 07-09-2008, 01:36 PM
A little clarification of terminology: ALL odometers are digital. Some are mechanical and some are electronic, but all are digital (which means showing digits instead of the dial and pointer of an analog gauge). Is anyone here old enough to remember digital clocks (with mechanical drive) that had numbers that flipped to change? Similarly, my 93 Allante has analog gages that are electronic (the LCD screen shows an analog gauge, even though it is generated electronically).
Old 07-10-2008, 09:52 AM
Hmmm,
At this point it looks like I will be doing both. I will keep you all updated. I think they will look really cool!
Mark
Old 07-10-2008, 09:25 PM
So far it is 7 for the old style
and 2 for the new electrical stuff ...
I had pinned this poll at the top for a few days ... now it is unpinned
Old 07-10-2008, 11:40 PM
I like the needle type gauges, probably because I am old. I just think the digits in a 55 Chevy or deuce look wierd. Actually I dislike the digits in my TownCar too.
I also prefer all my needles pointing straight up during normal operation. That makes it easier to scan. My periferal vision sees the needles so no direct focus to a gauge is needed. Itsa race car thing from decades ago, but it makes the gauges look strange all cocked twisted around at angles.
Also I use lights, buzzers, and gauges, since the light and buzzer draws attention sooner. Saved me one engine when my son was driving.
No gauge scan, light and buzzer comes on.... instant alert. Hard to ignore a red light and a 90 db piezeo beeper going beep, beep, beep incessantly.
Electric or Mechanical fan? Which do you prefer? Z-Money Pit Engine 13 11-15-2005 05:44 AM
