Do you remove masking tape in between coats? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2006, 08:14 PM
Do you remove between primer-base coat, and base-coat clear coat?
Old 09-27-2006, 08:25 PM
302 Z28's Avatar
I would remove it between the primer and base, but not between the base and clear. You normally wet sand the primer before applying the base, so that would get real messy if the tape was still on.
Vince
Old 09-27-2006, 09:04 PM
I do the same as vince. 99.9 percent of the time I remove it and retape and mask after primer before base. I normally wash the car after all bodywork and priming, sanding is done. Plus not unmasking after primer could make for a dirty paint job and primer may not get covered with color in jambs ect if you don't mask or roll back tape further. You should if you want a good job, although many production places don't retape, just dry sand blow it down. I don't remask between base and clear other then retaping something that may have gotten ruined after wetsanding a f up in the base.
window install Jzarczyn Body - Exterior 10 01-24-2009 11:02 PM
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-24-2007 11:40 PM
Basic of Basics - Windshield Installation Kits firebird_red Body - Exterior 15 11-26-2005 09:00 PM
Installing back glass on 66 gto.. help beemdubya Body - Exterior 4 10-12-2005 10:32 PM
When To Take Off Masking And Pinstriping Tape JimKramer Body - Exterior 3 04-20-2005 01:13 PM
