Do you think it will leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2007, 07:03 PM
seven1nova's Avatar
I just broke a oil pan bolt. (SBC 400) Around the center of the pan just behind the motor mount. (Torque 12lbs). just wondering if i should tear it apart to fix it or go with it, all other bolts are fine. what do you guys think.
and i did RTV the gasket
Old 03-03-2007, 07:05 PM
poncho62's Avatar
Wiki Edits: 5
I would be much more worried if it was on the corner bolts....I would take a chance on it....................
Old 03-03-2007, 08:23 PM
techinspector1's Avatar
Wiki Edits: 326
I agree, run it and see first. Next time, use grade 8 hardware, available at any True Value hardware.
Old 03-03-2007, 09:03 PM
seven1nova's Avatar
Yeah i should haved
but i'll try it and see what happens
thanks guys
Old 03-03-2007, 09:15 PM
topdogger's Avatar
Newskool
Last journal entry: New, Used grill arrived!
have you tried getting it out? Its amazing how easy it is to get some of those things out with the right twist bit.
Old 03-03-2007, 09:45 PM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
i got the same prob with my 70 el camino its not the corner bolt but its one over. im not havein any leakin probs. just make sure you use a good amount of hi temp gasket sealer. i dont think you will have any probs. im not and i changed my gasket about 3 weeks ago ive been keepin an eye on it jsut to see if it does leak but it hasent yet.
Holley Carb Gas Leak 64Joker Engine 21 07-18-2010 03:28 PM
Bad Oil Leak,,, Help! Lthompson Engine 8 08-15-2007 04:33 PM
Exhaust leak..will this fix it??? Z-Money Pit Engine 3 09-28-2006 07:03 AM
SBC intake oil leak, learn from my mistake! pcoghlan Engine 1 06-03-2006 06:29 AM
Need help finding a light oil leak! frankenvette Engine 5 05-26-2004 06:45 PM
