Do you use a engine lift plate? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-29-2011, 02:00 PM
302 Z28's Avatar
We used one of those levelers on a 74 Vette I was helping by friend with. We had a fully dressed out 350 with a Keisler Tremec six speed hanging off the back. It came in real handy once we had lifted it high enough to get over the long front end of the Vette. Sure was a little scary though.
Vince
  #32 (permalink)
Old 03-29-2011, 02:09 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Vince
Yep been there Vince on my old Vette and i feel your pain.
Cole
  #33 (permalink)
Old 03-29-2011, 09:24 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Originally Posted by Irelands child
Unfortunately many bolts found in the big box stores, ACE, etc are Chinese. Now, if you can trust their QC as well as steel quality..........go for it. If I need a ho hum Gr 5 for a non load bearing joint or for safety, I'll go to Tractor Supply and for a very few more cents will get their Gr8 and "assume" that it at least meets Gr5 specs. If I really need the strength, I'll go someplace like Fastenal or order from ARP.
Dave W
I agree, when I need really good stuff I buy my bolts from the local Caterpillar dealer, fortunately nowadays caterpillar carry both metric and sae fasteners
  #34 (permalink)
Old 03-29-2011, 10:04 PM
jessicafd's Avatar
I do on cast iron intake manifolds and have custom lift plates I have built.I have watched a 351 Ford hit the floor and dent the oil pan big time,one of my employees decided to use an engine plate and the threads for the carb studs were stripped.The intake was aluminum.Customer was not too happy and I ended up firing this guy that did this.I warned him twice to put a chain on it and never listened to me.
  #35 (permalink)
Old 03-31-2011, 11:42 PM
bentwings's Avatar
bentwings
Here is strength data on bolts.
http://dodgeram.org/tech/specs/bolts..._strength.html
I've used these for as long as I can remember and never had a probem. I also have one that attaches to a blower manifold that we use for the Funnycars. Even an all aluminum hemi is pretty heavy these days.
  #36 (permalink)
Old 04-01-2011, 04:14 PM
Wiki Edits: 27
bolt qc ok
Bolt manufactures use SPC and sample testing, the problem is HOW GOOD ARE THE THREADS IN THE MANIFOLD ? how many times have the studs been removed and replaced for a spacer, etc,, I've seen too many bad threads in aluminum manifolds. The adjustable crank bar with 4 chains , easier to get an engine in a tight compartment, and safer.
  #37 (permalink)
Old 04-01-2011, 07:05 PM
jessicafd's Avatar
I had an adjustable crank bar,I hated it and got rid of it.Nothing but a real PITA to me.Got rid of it 2 years ago,I was installing an engine in a Chevy truck and had enough of it.I got so mad,pulled the engine out,removed the adjustable crank bar bolting a chain on and went in the scrap pile.A friend of mine took it out and I told him he can have it.I have plates (1/4 thick steel) I bolt to the cylinder head I made with holes which a chain can be hooked into.
  #38 (permalink)
Old 04-03-2011, 10:55 PM
Engine plate
I have pulled out a Hemi motor, 6 BBC, 5 SBC, & 1 SBF all with the same engine plate. Never had a problem. Out of all those motors 10 of them had the trans attached too. Best $ I ever spent on a tool, Engine plate.
  #39 (permalink)
Old 04-04-2011, 03:50 PM
Originally Posted by Old Fool
I do not understand why some think a grade 8 bolt is necessary. The proof strength on a grade 5 1/4" bolt is 4165 lbs of load. Times that by 4 and you have over 16,000 lbs of lifting capacity.
As overedriv stated, the weakest point is the quality of threads in the manifold. Grade 8 bolts make no difference with this factor.
I was just going to comment on this thread and then read this. You are correct.
There is a LOT of misinformation in this thread. I can't remember the numbers but I seem to recall grade 2 being sufficient.. But don't quote me on that.. I just don't understand why you would run out and buy grade 8 bolts to thread into aluminum.
  #40 (permalink)
Old 04-04-2011, 05:15 PM
You're right. I bought the grade 8's for a feeling of comfort. I realize the aluminum intake threads would go way before the grade 8's, probably the bolts too, but for a couple of bucks why not? I store them with the engine lift plate now and I will never have to worry about them again.
  #41 (permalink)
Old 04-04-2011, 06:37 PM
bentwings's Avatar
bentwings
If you look at the chart I posted above you can see that Gr 2 1/4" bolts would be marginal at best. 1/4" Gr 8 will handle most any thing. 5/16 would be even better.
Don't forget that the load might not be evenly distributed. All of the load could be on only one bolt. Keep the plate tight to prevent this.
The rule of thumb is that in aluminum the fastener needs to be screwed in at least twice the nominal diameter. Steel it is 1 1/2 times the nominal dia.
  #42 (permalink)
Old 04-04-2011, 07:48 PM
You're missing our point though. Gr8 WILL handle most anything.. A lot more than the aluminum or cast intake, and probably even the lift plate. I'm not saying it's bad to use them. Just that there is no point.
It's like lifting a pound of butter with a stick jammed straight into the top. Doesn't matter if your stick is a toothpick, or a knife, the butter will yield first.
  #43 (permalink)
Old 04-04-2011, 10:33 PM
bentwings's Avatar
bentwings
I think what you are saying is that the tapped hole in the manifold will strip before the bolt strips or breaks.
Your analogy of the butter is ok.
So replacing the butter with aluminum the pull out strength in pure tension of the fastener if screwed in at least twice the nominal diameter will be pretty close to the fastener strength. It's really much more complicated than this.
Take for example a standard aluminum nut on a steel fastener assembled thru a steel plate. Were you able to pull in tension on the head of the bolt the aluminum nut would fail before the steel fastener. Now increase the nut size to at least twice the nominal height of the thread size. Now the shear value will approach the tensile strength of the area of the minor diameter of the bolt.
These plates would not be available if they were not reasonably safe to use.
As for the use of Gr 8 fasteners. I use Gr 8 on everything I can simply because I want no fastener failures ever and I buy them for about $3 a pound. A little more for certified ones. I see no reason to chintz on fasteners. In industry where we used hundreds of thousands of fasteners cost becomes a factor. Cost vs function then becomes the driver and the engineer is tasked with analyzing the situation to come of with a fastener that will do the job for the least cost.
In the shop anything that even remotely stresses a fastener gets a Gr 8 including nuts. Lifting anything gets the best equipment. You surely do not need to injure anyone due to faulty equipment.
The only application on the race car for deliberate fastener failure that I can think of is the blower attaching bolts. There aluminum studs are used with either a hole drilled thru and/or the body is thinned. These break off if the blower backfires preventing the blower from massive explosion and resulting shrapnel. You can see that even when aluminum nuts are used here and they seldom fail. Usually failure is from crossthreading and poor installation. A severe blower explosion will split the blower case, bust all of the blower bolts, cave the bottom of the manifold in besides popping the burst panel. The resulting fire will take care of the rest of the car but the shrapnel will be minimized.
I use them on my blower but I seriously doubt I could bang the blower hard enough on gas to split it let alone break the studs. They look cool and they were free.
  #44 (permalink)
Old 04-04-2011, 10:46 PM
Augusto's Avatar
I was thinking the same, never heard of a lawsuit against the plate manufacturers
  #45 (permalink)
Old 04-05-2011, 12:10 AM
Oh, I know they are safe (reasonably?) to use.. I mean, I don't like them, and I wouldn't use one, but to each his own.
I thought we were just talking gr 2-5-8 bolts now?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Lift engine while in car atlantis Engine 15 02-04-2005 12:37 PM
engine lift chevyman06 Garage - Tools 18 07-17-2004 02:04 PM
engine lift plate 6speedwagon Engine 2 04-24-2004 09:44 AM
Engine lift Plate 406chevelle General Rodding Tech 7 11-02-2003 01:19 AM
Lift Plate Que 39chevy Engine 8 10-03-2003 08:47 AM
