Do you use a engine lift plate?
Has anyone ever dropped an engine because it pulled the carb studs out of the manifold?
I've got one and I've used it, but d@mn it looks scary. |
lift plate
i agree with u on this.. i just don't trust them, but they are made to do what u are wanting to do.. lifting the motor.. i always use bolts on the front/rear of heads...
Never seen one break but DAMN it seems like there is a lot of force on those four little bolts! But then I get the heebie Jeebies with a only two bolts at each end of the heads as is usually used too. It just seems like a LOT of force on those bolts. But I have NEVER seen one break.
Brian |
Ditto on the bolts at each end of both heads. Grade 5 or better 3/8" in the accessory holes - never had one bent or broken and I usually pull the trans with the engine.
Call me paranoid, but I will not use one on an aluminum manifold, and when I do use one on a cast iron manifold I use grade 8 bolts.
Vince |
I have one and have use it but i will admit it does make me alittle nervous. :sweat: I usually go to the head like most do . But i do know guy's that they will use the plate just about every time and swear by it. :eek:
Cole |
I have a set of OEM Ford plates that I use along with case chain. Those screw links are not used - I use Gr8 bolts 3/8x 1-1/2 along with some extra header bolts:
http://i70.photobucket.com/albums/i8...DSC_0003-5.jpg I imagine Chevy has something similar or some can be made from some 1/4 to 3/8 stock. I also have a grunge set of valve covers so the chains wont damage my nice aluminum versions. Dave W |
The key IMO to safely using one of those engine plates with an aluminum manifold is using grade 8 bolts and above all make sure you have FULL thread engagement.
Vince |
Brian |
I know that when I was working as a mechanic at both the Chevy dealership and the Ford dealership neither one would let the mechanics use them, it could get you fired if you did.
Vince |
I have pulled big blocks with them plates, I made one myself, but I do admit that it makes me feel nervous, I use it because I figured that if they failed someone had already sued the manufacturer big time and they would of being recalled already, but I still see them on catalogs.
The tension that only one stud can hold is way much higher than the weigth of an engine, and 4 of them are used, it worries me more the integrity of the threads in the manifold, specially aluminum, but it's a lot more than we could imagine. |
I also use the plate to pull the engine and transmission together, with aluminum intakes also, but I admit I am a little bit nervous. I usually do about two pulls a year with this method.
Well I think everyone one feels as I do. I've lifted with the plate but it makes me nervous. The aluminum threads in the manifold is my nervous point.
4 1/4X20 threads in one inch deep is about the equivalent of a one inch bolt in an inch deep, but the threads in the aluminum have to be a good set of threads in all 4 holes, or I won't use it. And even then I use my chains when ever I can. I like these, one on each end of the engine. Makes it really easy to level the engine with these. |
The only thing I would lift with that thing would be just an intake.
Give me grade 8 bolts and a good loadbearing chain any day.And the factory lifting rings that are on Chevy engines,well I had one of those to rip open and dropped an engine once,thankful it was coming out. I just cant see trying to install an engine with only one point of lifting .Just an unbalanced load of alot of money hanging,waiting for catastrophy. |
| All times are GMT -6. The time now is 08:07 PM. |
