do it yourself convertible top
Hey guys---decided to do the rag-top myself- after hearing the prices to do it here locally- I could screw up 2 tops before i get it right and still save money! I need to know what the best adhesive is for gluing down the tack strips. Ive got a 69 galaxie i'm working on- and the old strips appear ( at least the header bow strip) to be - well- riveted in place--when i pulled the old strip off (it was rotted) There are studs left that the tack strip was attached to---but no rivet/stud head on the top side of the bow. The strips that i ordered, are just solid tack strips, so im confused as to how i can place the header strip on the bow- without either grinding down the studs, or drilling holes in the strip. Anyway---any advice would be welcomed, and specifically - the type of adhesive i need to use to apply the tack strips once I figure out how to solve the "stud" problem . Ive read most of the top install threads on-line and none of them mention the tack strips or well liner install.( Any galaxie convertible members out there?) Thanks guys, I really appreciate any insight on this.
First of all, good attitude. I figured the same as you and have now done three convertible tops for vintage Mustangs. Take your time, get a pneumatic staple gun and ratchet, and have a second person available to help you pull / stretch while you staple. You'll end up stapling/unstaping and bolting/unbolting the rear tackstrips several times before you finish, so using a power ratchet and a good staplegun are key.
As far as the pads are concerned, I used 3m Super 77 spray adhesive to close the pads, and used poprivets in the front bow and staples in the other bows. California Mustang offers a how-to video that is quite helpful. It is geared towards the Mustang, but should cross over for your Galaxie and give you plenty of good tips. Here's a link to the order site. VT3 is for the convertible top install. I've had the best luck with Robbins tops. Good luck. |
I appreciate the replies so far ! Thanks for the encouragement guys!
| Convertible top stopped working!!! | efhill321 | Electrical | 8 | 04-04-2005 07:05 AM |
| convertible top vs. hard top | billyr | Body - Exterior | 2 | 02-21-2004 06:48 PM |
| Top chop/vinyl top questions | tundrafiend01 | Body - Exterior | 2 | 01-19-2004 06:51 PM |
| Convertible top | DaveinNC | Electrical | 4 | 07-10-2002 12:27 PM |
| CHOPPING CONVERTIBLE TOP | FRMNDA1 | Body - Exterior | 0 | 12-09-2001 07:22 AM |
