Doa - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2010, 10:45 AM
Doa
I replaced coil and starter does not engage motor is dead all fuses good connections good.
Old 09-09-2010, 11:56 AM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Battery fully charged?
Old 09-09-2010, 04:28 PM
T-bucket23's Avatar
Wiki Edits: 26
More info needed. Why did you replace the coil.
Does anything work, headlights etc.
First thing to look at if if the engine is grounded properly to the body and battery. Check for power at the starter.
Look around where you were working on the coil and see if you knocked. something off
Chet
Old 09-09-2010, 04:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Your going to have to back track yourself. And by all means make sure the battery is fully charged.
I can't remember if you said in your orignal post or not, But was it running before you worked on it ?
Cole
Old 09-09-2010, 10:12 PM
randolphi's Avatar
lighting not off with the key.
Your added lighting can not share the brake light supply power, without some key activated, relays, so the battery and fuses wont be overloaded.
Old 09-11-2010, 12:12 PM
1 in a million
My dad and I pulled the starter just to 100% check everything and that was it Dead. It decided to die at the same time as I cleaned and rebuilt the tbi. Put on new starter and it fired right up. thanks for the help, it just shows how important it is no to rule out anything with out checking it first.
Lincoln 180T DOA.... Steel Garage - Tools 42 06-05-2008 08:28 PM
missing in action, or DOA. wizzonial Hotrodders' Lounge 3 01-26-2006 06:31 PM
