Doc, need relay help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2007, 07:01 AM
I have just installed a new kwik Wire harness and I used their relay for my electric fan. I used a toggle switch to activate. I have triple checked the wire routing and it is in accordance with the directions, but just as soon as I hit the switch it will blow the 25 amp fuse at the realy. Any suggestions?
Also, the wiring diagram shows only one #28 red wire going to the headlight switch. My buddy`s EZ Wiring diagram shows this #28 red wire spliced, and then attaches to the headlight switch in two places. I have no headlights, but do have tail lights. Should I splice and attach at two places? Thanx, Bob Myers.
Old 07-12-2007, 06:00 PM
Not Doc but it sounds to me like you have a fuse that is too small for an electric fan! I would think a minimum of a 30 amp and very possibly a 40 amp fuse.
Old 07-12-2007, 06:02 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Not sure of the size of your fan,
but my Spall twin 11" use two relays and two 30amp fuses
You may need a bigger fuse and/or relay
Twin fans should require 2 relays and fuses.
Give a few minutes and I will find my hl wiring diagram----also two places.
Battery power will go to------the headlight circuit ----AND----tail/park circuit
Bryan
Old 07-12-2007, 06:07 PM
Bryan59EC's Avatar
Found it
This is for a GM headlight switch
The headlights should be circuit breaker protected inside the HLswitch
the park/tail lamps are fused at the box
this is why there are 2 feeds to the switch
Bryan
Name:	hl switch.JPG
Old 07-12-2007, 07:56 PM
302 Z28's Avatar
This is a very good site for relay wiring diagrams.
Vince
Old 07-12-2007, 08:28 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Bosch relay FOR FAN:
  • RELAY COIL #85 Coil power FUSED (1 a amp) switched source.
  • RELAY COIL # 86 = Manual switch or switch controller device.
  • RELAY TERMINAL CONTACT # 87 = 12 Volt power source VIA FUSE LINK or MAXI fuse 40 amp..on a 10 gauge wire.
  • RELAY TERMINAL CONTACT # 30 = Fan motor via 10 gauge wire.
  • RELAY TERMINAL CONTACT # 87A = IS NOT USED.
HEADLIGHTS:
The head lamp wires will not come off the dash switch, the low and high beam wires are located at the HI/LOW switch or relay...there is where your connections will be.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-12-2007, 11:08 PM
doc, need relay help?
Guys, Thanx for the replies. I found my problem.....I have two fans and two relays. The fans are from a Ford windstar van and the two individual hot wires to the fan motors were connected in the small fan harness. I set my relays to work 1 off a toggle, and 2 off the thermostat in the intake manifold. When I would flip the toggle switch for fan one, both fans would attempt to start and blow a 30 amp fuse. I separated the two wires and now my fans are fine, thanx again, Bob Myers.
Old 07-13-2007, 03:37 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Bob,
Be advised, standard fuses are not generally up to the task of spike handling of a cooling motor..
I always advocate a MAXI FUSE or FUSE LINK for the DC source line for these..wouldn't do to pop a fuse 150 miles into the Desert without a replacement..or have to change them every other drive..
Doc
Innovations
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 03:09 PM
68 charger lights T-bucket23 Electrical 5 08-14-2006 05:07 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Choke relay question. Doc you out there?! pcoghlan Electrical 5 03-19-2006 11:11 PM
Omg, Car Fire!! Malibu1980 Electrical 21 06-16-2004 12:34 PM
