Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 01-10-2007, 05:11 AM
docnash docnash is offline
Doc's Toys
1953 Ford 8rbt V-8 Truck Flat Head. Temp Runs 180 To 190. Runs At Normal Temp While Driving. After Stopping, Vomits Thru Over Flow Tube. It's One Thing After Another When You Try To Finish A Project Started By Someone Else. Tested Thermostats And They Open Very Slow In Boiling Water..........i'm Thinking About Leaving Them Out Permanently. Flushed Recored (so He Said ) Radiator And Didn't See Any Rust. What Are Your Thoughts On Leaving Out The Stats ?? I'm Not Concerned About The Heater.
Doc
  #2
Old 01-10-2007, 06:11 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Generally not a good idea to leave the t-stat out, but depends on the vehicle. If flow is marginal it may help to remove it, but not likely.
Vince
Old 01-10-2007, 07:00 AM
poncho62's Avatar
poncho62 poncho62 is online now
Last journal entry: 51 Ford F1
Wiki Edits: 5
Flatheads were always known for overheating problems. I think the trick is to make sure you get all the air out of the sysrem. Don't run without a thermostat.
IGNORE TROLLS & THEY WILL DISAPPEAR
Ontario Rodders
Old 01-10-2007, 07:07 AM
pasadenahotrod pasadenahotrod is offline
Your temperature is not too hot at all. The puking after shutdown may be the result of filling the raditor too high.
On a pressurized system without a puke tank and return line the water level in the radiator is rarely at the top of the tank. My 40 Ford Std. Coupe with a stock 4lb. cap would always puke when stopped if the water level to begin with was higher than 2" below the radiator cap. I learned to avoid the embarrassing spill on shutdown by simply never filling the radiator over that level.
You may not have a heat problem, just a water level problem.
Old 01-10-2007, 10:43 AM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Is the cap any good and is the seal around the rad neck any good?
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Doc's Toys"
ThreadThread StarterForumRepliesLast Post
Doc's Toy'sdocnashEngine112-11-2006 06:31 AM
Doc's ToysdocnashElectrical111-19-2006 05:02 AM
Doc's toysdocnashElectrical409-06-2006 10:31 PM
Doc's ToysdocnashIntroduce Yourself109-06-2006 06:25 AM
Wife Is Ill- Any Docs In The House?NAIRBOff-Topic2404-18-2006 09:17 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
