A Dodge 383 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2006, 11:56 AM
A Dodge 383
Hello, I just got ahold of a dodge 383 that I want to put in my 1970 dodge dart. I'm looking for advice on how best to build it as an engine for occasional track use and all around hotrod. I'd appreciate an advice I could get. Thanks
Old 09-03-2006, 12:12 PM
Wiki Edits: 49
The 383 is a pretty potent engine even in stock form especially in a light body like your Dart.
If it was me, I would rebuild the motor using Mopar Performance parts and a "Purple" camshaft along with a dual plane MP manifold and a good set of headers. That combo will be very streetable and pretty quick on the strip.
If you're running a manual trans you can go a little hotter on the cam but keep in mind the most prevalent mistake most people make is over camming an engine.
You can also go to Moparts on the Web for additional info. You can also try the Big Block Dart website .
Good luck.
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
Supercharging and fuel injecting a 383 Chevy Noesis Engine 11 09-21-2007 05:51 AM
What makes a 383 so much more expensive? Chevy21 Engine 12 09-30-2004 08:55 PM
383 SBC in Dodge Dart? newchevyman Engine 5 09-18-2003 09:02 AM
