Dodge A604 Trans - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-23-2007, 08:04 AM
This pack has never been mounted. Was hoping maybe to get a little insight before I took it apart. So if it looks the same use the plate, if it looks different don't use the plate?
  #17 (permalink)
Old 03-23-2007, 09:38 AM
airworld2's Avatar
I am posting pictures to show you the plate and different packs.
late model no plate single gasket
early model plate two gasket and rubber cover
  #18 (permalink)
Old 03-23-2007, 10:05 AM
Thanks. This one is an old style. Since it has never been mounted or used I guess its worth a try. All it will cost is the price of the gaskets. Are both gaskets identical or is there a differance? Thanks for the pics, that answered a bunch of questions running through my non Chrysler brain!
  #19 (permalink)
Old 03-23-2007, 05:24 PM
airworld2's Avatar
early pack used 2 gaskets, yes they are the same
late only used one and is not the same as early gaskets.
Ideas for "MY" Trans AM 3rdGenFreak Hotrodding Basics 0 12-10-2006 02:09 AM
Jegs 350t trans..... No good!!!!!! tiresmoke55 Transmission - Rearend 15 08-11-2006 11:24 PM
727 Torque Flight trans problems Steves66 Transmission - Rearend 5 06-30-2006 04:11 AM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 07:45 PM
