Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dodge Charger Transmissions
Old 01-25-2011, 04:53 AM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by 36 Chevy Guy
Thanks, got the engine, trans, computer and all the engine accessories, but was only told that it came out of a 06' Dodge charger. All research makes me believe your right. My concern is I putting it all in a 69' Dodge pickup, and does that xmission have just a straight shift and no autostick. If so I'll have to come up with a floor shift of some kind regardless of the xmission. Don't know of a column shift for a 5 Speed. Thanks again
it was an option, the computer will have to be checked to see if the autostick is programmed into it. it still will have a manually operated shifter.
heres a thought, the trucks also have the option of a 5 speed trans (45RFE/5-45RFE) and they are column shift, and no autostick. while they are used for another type of trans, with some good fabrication, i dont see why it wouldnt work. the biggest problem your going to have is the park lock mechanism.
