Dodge Dakota Disc Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2010, 05:23 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
I am replacing the calipers and pads on a 89 Dakota 2 WD and I am at a loss where this "Frog Leg" wire is supposed to go.
I am sure it has to do with the anti rattle of the pads bit it does not want to fit anywhere and look like it is supposed to ride there!!
A pic would be worth 1000 words or more!!
Old 09-05-2011, 08:59 PM
solidaxel's Avatar
ANYBODY, have a picture of Dodge Dakota 89 caliper so I can see how the "cricket leg" attaches to the disc pad?
Old 09-06-2011, 04:31 AM
Last wiki edit: How to make a custom dashboard
Last journal entry: Been a long time
Wiki Edits: 4
This is the later style, but I think it is the same. Hope it helps.
ID:	58189   Click image for larger version
Old 09-06-2011, 07:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
This is why it's a good idea to take apart one side at a time.
Old 09-06-2011, 08:55 AM
S10xGN's Avatar
Gotta love a turbo!
You can go to Autozone's site and access full shop manuals for your vehicle (may have to sign up 1st). Also, make sure you have the right pads, I just bought a set for my '98 R/T and was given a set for a standard Dakota. Didn't find out until the front end was all apart, then the wife had to go to three other places before finding the correct ones!
Russ
solidaxel's Avatar
Everything on this truck came out of a box!!
I did not have one to look at it is all hand built, so I need a picture of one side to build my front brakes.
Thanks for the pic but it is on a 6 lug caliper and rotor which is "newer" than my 5 lug
Name:	Picture  07  to  08 476.jpg
ID:	58197   Click image for larger version
Name:	53 Chevy 948.jpg
Old 09-06-2011, 10:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
2WD CALIPER ASSEMBLY
FRONT BRAKE AND SPINDLE ASSEMBLIES
There may be more than just one caliper used, depending on the year by the looks of things. The top caliper above uses an attached clip while the bottom caliper above (and the 4WD caliper, below) shows a separate rattle spring/clip affair. In any event, you can see the orientation of it.
4WD CALIPER ASSEMBLY
Old 09-06-2011, 11:40 AM
solidaxel's Avatar
Now we are getting closer!!
Outboard pad spring.
Ok, I will see if I can orientate it in the right direction!
Thanks
Old 09-06-2011, 07:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Don't know how well it shows up on your monitor, but the two ends locate on the caliper, where the 'divots' are. Then the clip acts as a 'bail' to capture the outer pad.
Old 09-17-2011, 03:02 PM
solidaxel's Avatar
It still dosen't look right!!
Name:	53 Chevy 004.jpg
ID:	58421   Click image for larger version
Name:	53 Chevy 005.jpg
ID:	58422   Click image for larger version
Name:	53 Chevy 003.jpg
Old 09-17-2011, 05:03 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
The ends go in the holes in the caliper that are clearly visible.The loops go over the caliper mounts.
They do not go between the pad and the caliper.
Old 09-17-2011, 05:11 PM
LATECH's Avatar
Put the O s in the X s
then flex the spring into position where the arrows are
The clip should be on the outside of the caliper not between the caliper and the pad.
The third pic is close, just flip the spring/clip over put the arrows in my pic together on the caliper mount.
Old 09-17-2011, 05:16 PM
LATECH's Avatar
In cobalts post, pic #2 shows it pretty clearly
Old 09-17-2011, 06:14 PM
solidaxel's Avatar
O K, so what keeps the pad tight in the caliper, if it goes on the outside?
There appear to be a bit of clearance on the pad between the anchor and caliper. I thought this frog leg was to keep it from squeaking!
I tried that and it fits BUT what is it supposed to accomplish?
Old 09-18-2011, 01:59 PM
LATECH's Avatar
It keeps the caliper from clunking around when hitting bumps.
There should be anti rattle hardware with the pads, unless you got the cheapies, but you may be able to get it seperatley.
There is also an adhesive that can be used on the pads backing to keep them fixed tight to the caliper, but I prefer the proper clips.
Chevy PU disc brakes Randaddy Suspension - Brakes - Steering 2 10-06-2006 10:14 PM
4 Wheel Disc Brakes 66 GMC Truckin Suspension - Brakes - Steering 5 07-02-2005 11:50 AM
Ford Ranger 8.8" Rear Disc Brakes nightrain_rod Transmission - Rearend 1 06-23-2003 05:48 PM
disc brakes black66 Suspension - Brakes - Steering 2 05-02-2003 06:15 PM
83 Olds disc brakes NAIRB Suspension - Brakes - Steering 2 09-14-2002 06:47 PM
