dodge to ford engine swap
I have a dodge 318 and I was wondering how much trouble it would be to put it into my 1992 1 ton ford. I appreciate any input I can get thanks.
Because i have a really running engine. 460s are junk and I dont know how to know for sure I am getting a windsor instead of a cleveland. @ the former street racer i have the engine and trans. My ford is a 2 drive and the dodge is a 4. I can weld and have a couple of welders at my disposal.
Meant to say a really cheap runninv engine.
I had a 455 poncho in my 66 ford f250 so anything is possible.
Easy way to tell a windsor from a cleveland block is the thermostat housing attaches to the intake on a windsor and into the block on a cleveland. |
318's not gonna be much engine in a 1 ton Ford, doable tho, but you'll need some diffrent parts to run that 4x4 trans in a 2wd truck |
Is this gonna be a daily driver, or a Hotrod.
If this is a driver, trade the 318 for a replacement motor, or cash to buy a replacement motor. A 318 swap will require you to crossbreed the power steering system(ford steering, dodge pump, custom hoses) You'll need a 2 wheeldrive trans, or the ability to disassemble and convert yours to 2 wheel drive. A replacement(new, rebuilt,scrapyard, other) Ford motor(what do you currently have? ) is a bolt in, no fabrication, less time and money overall. And you could throw on a few aftermarket bolt in parts to improve the performance of the motor/truck. |
A 318 in a 6300 pound F350 is close to the worst possible choice - regardless of the fact a 318 is a great engine 460 Fords are far from junk. What they are is gas hogs. The difference between a Ford 'C' and a 'W' is simple You need some self education on engines before you make bald statements such as these to an intelligent group such as on Hotrodders |
| Tags |
| dodge, engine, ford, swap |
| Need advise on Ford 300 engine swap to a Ford 400 | aztek_warrior | Hotrodding Basics | 6 | 03-22-2011 02:59 PM |
| 56 dodge truck engine swap question | 56dodge | Engine | 1 | 07-31-2010 02:33 PM |
| dodge pickup engine swap | DR132 | Engine | 7 | 01-24-2007 11:05 PM |
| Dodge van engine swap | Lonestar | Engine | 3 | 07-21-2006 08:05 AM |
| 84 dodge engine swap | chris85 | Engine | 1 | 01-09-2003 08:22 PM |
