Dodge OD trans swap questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2010, 03:07 PM
octanejunkie's Avatar
Registered Looser
Last journal entry: Background: why I am here
So I have a 316/904 in my '71 scamp and want OD. I found a guy in AZ selling rebuilt "A500 (42RE) TRANSMISSION 90-02 DODGE RAM VAN 1500 4SPD " for $750, $145 shipping and no core charge, he has 10 of these to sell.
I am building a magnum 360 motor for the car and want an OD trans that will bolt right up. I like the ratios in the A500/42RE/RH trans (2.74,1.54,1.00,0.69) and am wondering if this will bolt up to my magnum block.
I will handle lockup with a conversion kit from PACT for $85 and get a good locking torque converter.
Anyone have any knowledge or experience with these transmissions and the swap in question?
Old 12-08-2010, 08:22 PM
LATECH's Avatar
The PACT website gives all the info you are looking for. I would opt to go with the 518 trans. It is a 727 with overdrive and uses a 2 wire connector for the over drive.You want a trans from 95 and back as 96 were electronic controlled for all gears as well as overdrive and lockup.
I would not run a 42RE as it is fully electronic and its very lightweight as far as strength, like v-6 dakota lightweight. Go with the 518 if it will fit the tunnel.The 500 would be a good second choice. just went throught his on a buddys dakota 360 magnum build ,he is not sure either as the tunnel in the dakota will need cut to accomodate the 518.
1993 Silverado K1500 auto to manual trans swap.. FinishLine Transmission - Rearend 1 01-11-2009 08:42 PM
4 Spd Ford truck trans swap questions 68F100 Transmission - Rearend 2 01-06-2009 07:54 AM
'98 dodge trans question Jmark Transmission - Rearend 4 12-19-2006 05:48 PM
Borg-Warner R10 Overdrives? packratwrecker Transmission - Rearend 38 12-27-2005 08:44 AM
If anyone has questions about 94 town car, motor swap Rubberman2003 Engine 1 02-11-2005 02:18 PM
