Dodge Stepside 1952 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2007, 12:11 PM
Dodge Stepside 1952
Hi, Iv Just Joined This Forum, I Am In The Middle Of Customizing My Dodge 1952 Step Side Pick Up, But Im A Bit Stuck On Changing The Front Clip,to A Upgraded One. Iv Taken The Old Drum & King Pin Set Up Out But Im Having Trouble Finding A Replacement Ifs With Discs, I Live In Bristol,& Run A Small One Man Garage, For Services And I Do A Small Amount Of Spraying Self Taught For Around 15 Yrs, If Any One Can Help I Would Be Most Great Full, Sorry About Spellings. Regards Rob
Old 04-09-2007, 12:29 PM
Boris ...
WELCOME to Hotrodders.com
The early Dodge pickups are gaining in popularity with the early crowd ..
I have a friend who is doing a WOODY ...
I have no technical help for you ... but I am sure some of out other members will ...
This board has spell check ... so you do not have to be a great speller ... it is on the same line as the submit reply button ... I use it quite often ...
again WELCOME ...
Deuce Moderator
Old 04-09-2007, 10:27 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I am not familiar with dodge at all, but the mustang II IFS is a popular swap under almost anything. I would recommend checking with some of the manufacturers like "fat man fab" and see what will fit.
Old 04-10-2007, 12:09 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Street Rod Engineering has a crossmember kit:
http://www.streetrodengineering.com/...gllifskits.htm
My 1950 Dodge Coronet And 1952 Plymouth Cranbrook 1950 dodge coronet Introduce Yourself 3 01-08-2007 07:50 AM
My 1950 Dodge Coronet And 1952 Plymouth Cranbrook 1950 dodge coronet Introduce Yourself 2 10-02-2006 05:19 PM
440 Dodge Stepside Todzrod Introduce Yourself 5 08-31-2006 03:51 PM
1952 Dodge Pickup Front End fordson Introduce Yourself 2 01-21-2006 07:39 PM
1952 Dodge Pick up - C4 trans - speedometer John Frederick Transmission - Rearend 2 09-05-2003 11:58 PM
