dodge truck question...... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2009, 11:13 AM
skylark65's Avatar
Last journal entry: 4 months, nothing done...
wow, i have not been on here in ages, haha. once again, i find myself hunting for some realiable info for something OTHER than my buick (what else is new )
so, to get to the point, im looking to buy an 88 dodge 2500 "sno commander" pickup, nice red & silver, red cap, LE interior, has a plow & new tires, & low miles.
the truck is has a 360 with a throttle body, auto trans, disc brake front end, manuel locking hubs, dana 60 rear & dana 44 front end..... and its WAY cheep
only problem is that the drivers side front axle in the dana 44 is destroyed, compleatly demolished.... and i have only been able to track down a front drivers side axle with the drum brake setup on it, while the truck has discs!
my question is: would the drim brake axle be the same as the disc brake axle? i would really like to have this thing togeather enuff to plow with by winter....
-OR- does anyone know where i could buy a new axle for cheep, or anywhere i could purchase a used one in NEPA or north jersy?
thanks for any help, let me know if any more info is needed
Old 08-24-2009, 11:54 AM
prostreet6t9's Avatar
Differential/Driveline
Most of the time the drum brake outer stubs won't work in a disc brake set up. Is the tag still on the front cover bolts? If the tag is gone,the same number will be stamped on the drivers side axle tube. Its a 6 digit number that starts with a 6. If you give me that number I can give you the part number you need to look for.
Old 08-24-2009, 12:24 PM
skylark65's Avatar
i wish i had that number, but as of now the truck sits 30+ miles from my house, so thats a no go today..... but hopefully when i do get back down that way i will check it out..... thanks for the info
Old 08-24-2009, 12:39 PM
Is it a disconnect axle with the shift fork on the RH side axle tube?
Old 08-24-2009, 01:40 PM
If it's a NON disconnect axle and I take a educated guess,the axle assy would be:
Complete assy part# Spicer 71628-2x. Thats inner axle,outer axle and U-Joint.
Inner axle alone is,Spicer# 27902-12X and is 36.78 in length,center of cap hole to end of axle.
Ouer stub axle,Spicer# 620200. 9.72 in length,center of cap hole to end of axle.
U-Joint Part# 5-760X.
If it's a Disconnect axle the axle assy# is: 73578-2X
Inner axle is the Spicer 73579-2X and is 18.32 center of cap hole to the end.
Outer stub is the same 620200
U-joint is the same 5-760X
To be 100% certain I really need the assy number off your housing,or the measurements off your axles, as there is 2 or 3 different option's in that year of truck.
Factory truck bed sealant question schnitz Body - Exterior 3 04-08-2009 07:59 AM
'98 dodge trans question Jmark Transmission - Rearend 4 12-19-2006 05:48 PM
'99 Dodge pu question Jmark Transmission - Rearend 3 06-23-2005 09:48 PM
Looking for info on interchange of 1950 f2 truck body to 1986 3/4 dodge extended van Ken Cunningham Introduce Yourself 7 07-23-2004 08:28 AM
Dodge pickup question newchevyman General Rodding Tech 1 02-08-2004 11:00 PM
