hi,
im not much into fords, but im pretty sure the Cleveland and the modified use different mounting and a different bell housing pattern. i think the heads may interchange but im not sure thanks jeff |
I'm pretty sure the whole 335 series (Cleveland, M, and 400) use the same motor mount, but this mount is different than the windsor and big block mount. The M engines (351-M/400) use the big block bell housing, while the 351-C uses the small block bell housing. I don't think the 351-W bell housing is interchangeable with anything other than a 351-W, but I think Woodz will have some good info to add, too.
The heads and pistons are also somewhat different between the C and M, because the M series has a taller deck. If I'm not mistaken, the heads are interchangeable between 2bbl Clevelands and the 351-M/400, but not CLeveland 4bbl's (M's didn't come with 4bbl stock). The intake manifolds and/or pistons are not between the 351-C and 351-M/400. But everything is interchangeable between the 351-M and 400. |
motor mounts
The cleveland and winsor ( including small block) share the same bellhousing and engine mounts. The M block shares bellhousing pattern and motor mounts with the Lima or big block.
You have been confirmed on that issue. |
