Does 400 turbo need to be vented - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2012, 05:42 PM
406 bug's Avatar
9.82 @ 139mph
Hey Guys, have a TCI 400 turbo that is leaking. It does not appear to have any kind of vent. Also the filler is sealed (threaded cap). I seem to remember the folks at TCI saying that venting was not necessary, and now that it is leaking, I feel its building pressure and blowing by the pan gasket. What say you. Thanks in advance for your knowledge.
Old 04-28-2012, 07:55 PM
Factory T400's all come with a vent, near the top of the case. If its a sealed case, you'd have a hell of a time filling it with fluid.
Old 04-28-2012, 11:44 PM
406 bug's Avatar
9.82 @ 139mph
As indicated, the filler tube has a threaded cap, to fill, the cap is removed (unscrewed). I just don't recall any seperate vent tube. Exactly where does the vent exit the case. Thanks
Old 04-30-2012, 01:33 AM
If you dont have a vent, the fluid will back up in the fill tube because their is no place for the air in the trans to go. That is what I meant when I said you wont be able to fill it.
TH400 vent
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
vented gas cap, how to modify non-vented 71delux General Rodding Tech 7 12-04-2004 10:37 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 01:35 PM
400 turbo to 350 turbo problems mikeweyman Transmission - Rearend 2 04-02-2003 06:58 PM
350 turbo or 400 turbo? nd500 Transmission - Rearend 2 02-21-2003 09:25 PM
